20 Most Recent Jacuzzi 3/4 Hp Cygnet Pump Questions & Answers
This could very well be low water, it should be half way up the tile or the skimmer throught. Also check your skimmer weir door. If it get's stuck in the up position it will do the same thing. To be sure start the pump then watch the water in the skimmer. If it sucks dry then it is one of these things.
Jacuzzi 3/4 Hp... | Answered on May 16, 2010
Replace your starting compassator or starter relay.
Jacuzzi Garden | Answered on Nov 04, 2013
Operator must be in the seat while PTO is engaged so most likely the seat switch has failed or displaced.
Garden | Answered 7 hours ago
You cannot just take the bolts out and get the blades off, you would need to open the gearbox housing, the blades run on an eccentric inside the gearbox, this is what makes them reciprocate, the box will be filled with grease, so a pretty messy job, just wire brush them on the machine and re oil if you do not want to strip the gearbox.
Garden | Answered 9 hours ago
Unfortunately there is no way to clean the carb without removing it, and disassembling it, you can replace the fuel filter in the fuel tank fairly easily, just hook the hose out through the open filler hole, pull the filter off the end of the hose and replace with new.
This machine is running too lean ( insufficient fuel getting to the cylinder ) things that make it run too lean are.
Blocked fuel filter in the fuel tank.
Cracked or split fuel pipe.
Incorrect settings on the carb.
Dirt or blockage in the carb
Diaphragm's hardened in the carb
Things you can do yourself, hook the pipe out of the fuel tank and replace the filter on the end, if you are not mechanically minded you will need somebody to service the carb, and re set it for you.
Yes, valves work best if they seal properly. Better compression equals more power as well as less risk of burning the valve edges as burning gas leaks past them.
Garden | Answered 10 hours ago
Jacuzzi 3/4 Hp Cygnet Pump Logo
2 questions posted
Top Jacuzzi Garden Experts
john h
Bath and Spa Parts...
Jay Finke
Jay Finke
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Garden
  • Jacuzzi Garden
Most Popular Question
water fills pump basket area empties
  • Garden
