20 Most Recent Rule H53sp 24mgra Swimming Pool Cover Pump Centrifugal Computerized Questions & Answers
0answers
Pump does not run. I
no send it to rule they have a 3 year warranty
6/3/2015 4:36:57 PM • Rule H53sp... • Answered on Jun 03, 2015
Wayne WAPC250 1/4 Auto On/Off Pool Cover Water Removal Pump
good pump its a rule by the way a lot of times the automatic goes bad cause the hoses frezes and the pump goes bad
6/3/2015 4:27:35 PM • Rule H53sp... • Answered on Jun 03, 2015
Rule 1800 gph pool cover pump will not run
The sensor that checks for h20 every 10 seconds may not be working properly. First make sure the pump is unplugged then clean the pump making sure the impeller is free never do this with it plugged in. tap the pump lightly with a screw driver handle to make sure the bearings are not frozen if it still does not work send it back to the manufacturer
9/24/2014 3:36:07 AM • Rule H53sp... • Answered on Sep 24, 2014
How do I get a replacement pump
go to buy pool parts on line dot com they have them
9/17/2014 2:37:37 AM • Rule H53sp... • Answered on Sep 17, 2014
Pump continues to run and won't shut off
clean pump
10/16/2013 12:12:25 AM • Rule H53sp... • Answered on Oct 16, 2013
Had ice on cover and it stopped running only 3 yrs
Thank you for posting your question here on Fixya.com.
Sorry to hear you are having trouble with the pump. Unfortunately there is no reset or other means of restoring your pump to operating condition. If the unit is out of warranty there is no cost effective means to get parts or to have it repaired. You may be interested in knowing they warranty the pumps for 3 years. Thanks to www.automaticpoolcovers.com for pulling this rule warranty information together. They sell many of these with the pool cover systems and their site tells you all you need to know about dealing with Rule warranty issues. You can find that information at:http://www.automaticpoolcovers.net/pdfs_new/Rule%20Pump%20Warranty.pdf Or Rule direct at www.rule-industries.com.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
2/6/2011 8:20:48 PM • Rule H53sp... • Answered on Feb 06, 2011
Rule800 PoolCoverPump won't turn off automatically anymore
I have the same problem with mine. I am looking for an answer.... If I find it I will post it.
2/5/2011 3:01:40 PM • Rule H53sp... • Answered on Feb 05, 2011
When you plug the pump
Make sure the pump is not filled with debris
12/18/2010 3:50:31 PM • Rule H53sp... • Answered on Dec 18, 2010
How can we measure the NPSH available & NPSH
Yes, but some extensive education is involved if you want to do it. It would take 5-6 pages for me to explain. Here are some links to the math and ideas involved in calculating NPSH.
http://www.mcnallyinstitute.com/11-html/11-12.html
http://www.engineeringtoolbox.com/npsh-net-positive-suction-head-d_634.html
http://www.pumpworld.com/centrif5.htm
If you have alot of time on your hands, and you llike to read, this will help.
11/23/2010 10:36:18 PM • Rule H53sp... • Answered on Nov 23, 2010
Is there a number to contact Rule directly?
The number I have for them is 978-281-0573.
John
11/12/2010 3:36:39 PM • Rule H53sp... • Answered on Nov 12, 2010
Cracked fitting on pump which connects to hose
Try the online store at www.thepoolman.com
7/10/2010 11:19:01 PM • Rule H53sp... • Answered on Jul 10, 2010
Cracked fitting
you should be able to pick it up at a local pump supply store look under pool repair .
3/2/2010 3:57:45 PM • Rule H53sp... • Answered on Mar 02, 2010
Rule HP53sp-24 Pool Cover Pump Control Board
The manufacturer is not going to provide a detailed PCB layout for there product with that sort of information. If you can not get it from the old part your only other option would be to try and get the info off a new pump.
You should also realize that the resistor did not just fail on it's own. They fail due to high current and/or heat which would suggest a more significant failure.
11/2/2009 12:55:21 PM • Rule H53sp... • Answered on Nov 02, 2009
High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
4/19/2009 12:59:13 PM • Rule H53sp... • Answered on Apr 19, 2009
Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
4/19/2009 12:55:41 PM • Rule H53sp... • Answered on Apr 19, 2009
I have a rule 1800
That's a good thing. That pump uses resistance on the impeller to alert it to the presence of water. It will periodically start and run for a few seconds. If there is any water present, it will keep running, otherwise it will shut off until the next time it tries. Put it in water, and see if it works there.
3/26/2009 5:41:11 PM • Rule H53sp... • Answered on Mar 26, 2009
Rule H53sp 24mgra Swimming Pool Cover Pump Centrifugal Computerized Logo
Popular Tags
21 questions posted
Top Rule Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Rule Pool & Spa
  • Rule Pool & Spa
Most Popular Question
measure npsh available amp npsh
  • Pool & Spa
