20 Most Recent Jump Start 4' Fluorescent Plant Grow Light System Questions & Answers
There are three major types of lighting systems available right now: incandescent, fluorescent, and high intensity discharge. Incandescent lights are horribly inefficient (especially the screw-in "grow bulb" type) and really not an acceptable option for plant growth. Although they are inexpensive to purchase, their cost of operation makes them the costliest source of light.
Jump Start 4'... | Answered on Nov 08, 2017
That depends on what you're trying to grow and what phase the plant is in. Certain plants are adapted to grow in the shade or in warm, sunny environments. Depending on the plant, one type of light may work better than another. For example, if your plant needs a shadier environment, then a regular incandescent bulb may work best.
The other factor that goes into choosing the right grow light is what phase your plant is at. For example, a high-pressure sodium bulb may be best when your plant is in the flowering or fruiting stage.
Personally, I love using LED grow lights. Modern LED bulbs are more energy-efficient (they produce more light with less power), so they cost less in the long run. They also produce less heat, which means you don't have to worry about a ventilation system. Plus, they emit light wavelengths that correspond to the peak absorption peaks for most plants.
When choosing your bulb, you should look at the requirements of the plant and how those requirements change as the plant continues to grow. Keep in mind that the larger your plant gets, the more light it will need, so plan ahead.
Please elaborate "jump start".
I'd begin by checking battery voltage first, then fuses, and ignition switch for power.
Jump Start... | Answered on Mar 28, 2019
What make of motor and HP of mower motor? https://www.6ya.com/callphilipforhelp
Garden | Answered 3 hours ago
how would we know?? its your mower
Garden | Answered 4 hours ago
According to the manual ''The engine serial number is located on the right side of the engine crankcase''
Link for manual for your reference >
https://www.manualslib.com/manual/1235821/Kioti-Dk451.html
Garden | Answered 11 hours ago
Why does my cutter blade keep slacking off
Garden | Answered 18 hours ago
do all of us a favor and google the manual. save time
Garden | Answered 20 hours ago
As a customer, the advantage is that I don't have to drive to the florist. Saves time and gas. I could make a phone call, but then I wouldn't see the available flowers.
Garden | Answered Yesterday
http://www.fixya.com/answer/answerpageslideview.aspx?thid=27295477&ctg=500
Could be...
  1. Fuse
  2. PTO Switch
  3. Relay
  4. Bad connection
  5. Low battery voltage
  6. Failed clutch
Jump Start 4' Fluorescent Plant Grow Light System Logo
3 questions posted
Top Jump Start Garden Experts
roeb
john h
Marvin
Marvin
Are you a Jump Start Garden Expert? Answer questions, earn points and help others
View Most Popular
Jump Start Garden
  • Jump Start Garden
Most Popular Question
best grow lights grow marijuana
  • Garden
