20 Most Recent Jeanie Rub Variable Speed Professional Back Massager Questions & Answers
Jeanie Rub Service Information Jeanie Rub Warranty Information
Core Products provides a full one-year warranty on all defects in material and workmanship. Any misuse, unauthorized repairs, or product abuses are excluded.
Defective products reported within one year of date of purchase will be replaced or repaired. Call the Customer Service department at Core Products at 800-338-7014 for a return authorization number and to arrange shipping.
Out-of-Warranty Service
Core Products will repair most Jeanie Rub Massagers after the warranty has expired. Some of the very early models can not be repaired but can be returned for a $50.00 credit towards a new unit.
It is difficult to determine the extent of the repair until the unit is inspected however, we guarantee the service call will not exceed $89.00 plus shipping.
Basic Service Package - $49.00 + $13.00 Shipping
- Cleaning
- Replace worn parts & pad
Complete Service Package - $89.00 + $13.00 Shipping
- Cleaning
- Replace motor
Cord Replacement - $25.00 + $13.00 Shipping
- Replace worn cord
Jeanie Rub... | Answered on Nov 12, 2017
- Cleaning
- Cleaning
- Replace motor
- Replace worn cord
There is a 90-day warranty on any service that is performed by Core Products International.
Where to send it
Core Products International, Inc.
RETURNS DEPARTMENT
1505 Parker Ave, PO Box 627
Chetek, WI 54728
If you have any questions regarding our service information please call 800-338-7014.
Jeanie Rub... | Answered on Apr 18, 2017
1-800-338-7014
- Cleaning
- Cleaning
- Replace motor
- Replace worn cord
Where to send it
RETURNS DEPARTMENT
Chetek, WI 54728
Jeanie Rub... | Answered on Feb 16, 2013
There is an adhesive label on top of the unit. Use a single edge razor blade to lift the label from either side (left or right) until the two recessed hex nuts are exposed. You will need a 9mm socket to remove these hex nuts. Be careful as there is a 6mm jam nut at the base of the threaded rod that holds the rod against the top of the motor housing.
Once you have removed the two hex nuts, be sure to save the tiny washers in a safe place. Once the handle is off, you might want to mark the black wire that is conected to the white wire to ensure that reassembly enables the proper connections.
Once the handle is off, you can take a small pair of needle nose vice grips and squeeze the cord retainer to facilitate the removal of the handle completely after removing the wire nuts.
Be sure all wire ends are marked to your approval.
The jam nut on the threaded rod needs to be loosened in order to lift the motor housing off of the motor. Use only a drop or two of penetrating oil on the threaded rod. Attach the two hex nnts removed earlier at the top of the threaded rod to create a jam nut at the top, by tightening them together. Holding these with a wrench, use a 6mm open end wrench or tiny vice grips to loosen the jam nut. Be sure the 6mm jam nut freely moves to the top on each side.
Remove all hex nuts and the motor housing can be lifted off.
Be very careful not to let the motor tirn over or you may lose the springs.
Jeanie Rub Service Information Out-of-Warranty Service
- Replace worn cord
RETURNS DEPARTMENT RA#XXXXX
Chetek, WI 54728
There is an adhesive label on the top of the motor.
There are two very small hex nuts that hold the handle tight against the motor assembly. You can take a sharp single edge razor blade and lift the adhesive label from the motor on either side, the left or the right just far enough to expose the hex nuts. Use a small 9mm socket to loosen the hex nuts enough to slide the cover out. Retighten the hex nuts. Use a strong glue like Gorilla glue to reattach the label.
I sewed some "1-inch" wide elestic straps on each end to the cover to prevent it from sliding....that was over ten years ago and it works great.
- Cleaning
Where to send it
After you have gotten an RA number from customer service, please send the unit to:
Chetek, WI 54728
1-800-338-7014
Try rotating the pad about half a turn.
Jeanie Rub... | Answered on Nov 28, 2011
no
fixya site fixes nothing
Jeanie Rub... | Answered on Dec 22, 2017
Hi ring core product they might b able to help ,,877-249-1251.....cheers
Jeanie Rub... | Answered on Nov 05, 2017
Jeanie Rub Variable Speed Professional Back Massager Logo
19 questions posted
Top Jeanie Rub Health & Beauty Experts
Colin Stickland
Colin Stickland
Bill Boyd
Jeff Tilburn
Jeff Tilburn
Are you a Jeanie Rub Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Jeanie Rub Health & Beauty
Most Popular Question
need change
  • Health & Beauty
