20 Most Recent
Evenflo Snugli Front & Back Baby Carrier Questions & Answers
Front carrier to back carrier
I went to this website:https://plweb.evenflo.com/replacement_parts.aspxtyped
in the model number and manufacture date (both are on a label on my
Snugli), and a pdf of the instruction manual came up. Hope this helps!
By
terraplnr
Aug 03, 2008
Instructions for putting on a Snugli
Call Evenflo customer service at 1-800-233-5921. I threw away my instructions too. I called gave them the model and manufacturing date and they emailed me the instruction manual. They will also fax or send regular mail too. The model and manuf dates are on inside of carrier next to where the armpit leve is. Hope this helps
Snugli Problem
none of ur pics work.. maybe upload some more and ill try to help!
No date of manufacture on my snugli
is it possible that your PO number stands for produced on number you may be able to use that as the manufactor date
on my snugli you put the baby in facing out and you fold the top of the front down and buckle it where youwould for the head support if they were facingin hope it helps and if it does can you leave me a good rating thanks
I have an evenflo front
I had the same problem with our snugli serenade...
I used model number 0651767 mfg date jan 01 08. It found part number 25707046 that was a downloadable pdf.
May be a newer model but it seems the same as my 2005.
Hope that works.
I can't figure out how
If you are using the same one that I have...you put it on the same way as if the baby if front facing against you instead you place the baby outward and the piece that would normally support their head folds down in half away from you and the 2 straps that supported the head now holds that piece folded down and gives the baby added support when you lean forward. I hope this helps if not post another problem and I will try to explain again. Good Luck...
Change
typed in the model number and manufacture date (both are on a label on my Snugli), and a pdf of the instruction manual came up. Hope this helps!
Insufficient neck support
Go to this link;
http://www.evenflo.com/Default.aspx?tabid=203&categoryid=6326fc52-edbf-4948-85f0-37105d7f03ec
You can get a user manual, check the FAQ's and they have several installation and adjustment instruction videos.
Hope this helps :)
Need printable manual foe Chase Evenflo car seat 30621633
Possibly similar model manual from manufacturer:https://www.evenflo.com/on/demandware.static/-/Sites-evenflo-Library/default/dw009a2787/Instruction%20Manuals/25701061%20-%20Chase%20Select%20EN%20Jan17.pdfReplacement parts from manufacturer:https://www.evenflo.com/parts-accessories/car-seat/30621633/30621633_parts.htmlhttps://www.evenflo.com/support/instruction-manuals.html
https://www.google.com can be used to search for manuals, but unfortunately, the one I found appears to be a different model.
https://www.manualslib.com/products/Evenflo-Chase-4041185.htmlPerhaps you could contact a retail store or internet site that sells that particular model and ask for a copy of the manual.
I need instructions to assemble Evenflo Pack and Playyard.
Hello, Lenda -
The Evenflo company web site does offer instruction manuals for many Evenflo products:
There is a section on that web page, with the heading Playards & Portable Beds. Perhaps one of the model names listed there is the model name for your Pack and Playard.
If not, then I suggest you contact Evenflo Customer Service and ask for assistance regarding the locked side rail. This is the link to the Evenflo Contact Us web page:
https://www.evenflo.com/contactus
If you reside in the USA or Canada, you will find a telephone number to call. Otherwise, you can fill out the form on that page to send as an email message.
Best wishes.
