20 Most Recent Metabo SXE450 00458 6'' Random Orbit Sander Questions & Answers
Sander doesn't spin
YOUR BALLBEARING where the disk is on mounted is the right bearing that have the problem for shure it is full of dust or completely dry it will not turn anymore SIMPLY TO CONTROL IF YOU MOVE YOUR DISK NOW ON YOUR MACHINE YOUR ARMATURE TURNS DIRECTLY WITH THE DISK thats not good the armature must stand still , replace the ballbearing or remove it and open it with a very little sharp screwdriver on the both sides solvent it out try to turn the bearing carefully until its turns without problems dry it or blow it out with a compressor and if its dry lubricate with ballbearing grease close it again and mount it again
1/5/2016 6:58:52 PM • Metabo SXE450... • Answered on Jan 05, 2016
I am unable to remove the backing pad. Any ideas
have you tried holding it with a vise..
not sure what type of lub to use, but teflon spray shouldn't hurt anything
11/9/2009 12:48:33 AM • Metabo SXE450... • Answered on Nov 09, 2009
Metabo SX E 400 (600405000) Random orbital sander. I cannot remove the backing plate as the allen wrench socket is stripped.
Question edited for clarity. Question moved from Cars and Trucks. The manual doesn't say it has a left hand thread, so anti-clockwise should remove it. So the hole in the middle of the s*c*r3w that should have 8 flat is completely circular. The way to remove would be with a s*c*r3w extractor, and it may even bite in the hole you have with no further drilling. They are cheap enough on Amazon https://www.google.com/search?q=screw+extractor+set ..
12/13/2022 11:34:44 PM • Metabo Tools &... • Answered on Dec 13, 2022
Bearing change
Yes the bearing of the disk or clean it only by remove the sites with a little sharp screwdriver solvent it clean blow it out and re grease it close it again on the sites and mount again .
1/5/2016 7:00:49 PM • Metabo Tools &... • Answered on Jan 05, 2016
Metabo sr358 plate removal
Are you removing the plate from the top (4screws) or trying from the bottom. It appears that the eccentric is a loose press fit. I am looking at a breakdown but it is not really all that clear. I would suggest going to Metabotools.com and under downloads type in your model number which is 600358-42, the 6 is already in place so what I did is add a 1 to the end of it and found the tool. Let me know but did you also check the clamps for the reason. Usually the platen is sold as an assembly.
1/12/2009 9:53:31 PM • Metabo Tools &... • Answered on Jan 12, 2009
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
3/18/2024 5:15:05 AM • Tools & Hardware... • Answered on Mar 18, 2024
Vibrapower Disc model BW-5040 exercise machine. E4 flashing on a Vibrapower disc model 5040. Replaced power cable
Question edited for clarity and typos. Question moved from Office Equipment category. It appears to be an unknown machine with no support and only mentions of people selling them. https://www.google.com/search?q=vibrapower+disc+5040+E4+error https://www.google.com/search?q=vibrapower+disc+BE-5040 A manual will often lead the the maker. https://www.google.com/search?q=vibrapower+BE-5040+manual ..
2/2/2024 1:34:19 AM • Tools & Hardware... • Answered on Feb 02, 2024
2answers
Where can I get replacement parts for my Tradesman BD460VM belt sander?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=Where+can+I+get+replacement+parts+for+my+Tradesman+BD460VM+belt+sander%3F
12/5/2023 10:35:53 PM • Tools & Hardware... • Answered on Dec 05, 2023
2answers
How to load a black and decker staple gun model dn418/d16
What width staples go in this gun ?
I have a box of T50 staples here labeled 5/16 , 8mm, but they are too narrow when dropped in to the channel in the stapler.
11/12/2023 6:22:42 PM • Tools & Hardware... • Answered on Nov 12, 2023
Metabo SXE450 00458 6'' Random Orbit Sander Logo
3 questions posted
Top Metabo Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Metabo Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Metabo Tools & Hardware - Others
Most Popular Question
sander doesnt spin
  • Tools & Hardware - Others
