20 Most Recent
Electric Hedge Trimmer, 18" Questions & Answers
Electric Hedge trimmer will not cut
more than likely it damaged the inner gears or drive pins that make the blades reciprocate and need replaced. if you would like instructions to repair it yourself i will send you them or you can take it to a service center.
How many chain link and what size is on the Mastercraft mc-2000, also it is electric so how much power output is there?
- I apologize, but I am unable to determine the specifications of the Mastercraft mc-2000 chain link as there are many different models and variations of Mastercraft chain saws with different specifications.
I suggest checking the user manual or contacting the manufacturer directly to obtain information on the specific chain link size for your model.
As for the power output, I also cannot provide a specific answer as it will depend on the specific model and its motor specifications. However, electric chain saws generally have their power output measured in amps, which can range from around 8 to 15 amps.
Black and Decker HP9048 Type 1 battery pack
if you're looking for battery packs that will fit the screwdriver, you might check on ebay and alibaba with merchants who are selling your product. It's possible that they could still be selling a generic brand of the rechargeable battery for your device as well.
Thank you.
Electric flymo 330 motor has bits of black gunk on it, can I remove it
See if you can turn the shaft easily. If you can't, just buy a new motor. It's bearings are seizing up.
If the motor spins okay, the start/run capacitor may need replacing. You can spray the motor and junk with WD40 to clean it. The last motor I have that smoked in a vacuum cleaner self destructed in less than a minute. The tech told me it would. Smoking is extreme overheating, or the windings have shorted internally. The best bet is replace the motor.
