20 Most Recent Craftsman 22" Gas Hedge Trimmer Questions & Answers
Recoil starter spring install
PartsTree repair clinic can give byou a video
2/6/2018 2:53:07 PM • Craftsman 22"... • Answered on Feb 06, 2018
I need gas/oil ratio for a craftsman weedwhacker 25cc 2 cycle curved handle?
50:1 will work manufacturer calls for 40:1
1/18/2018 9:57:51 PM • Craftsman 22"... • Answered on Jan 18, 2018
Gas hedgetrimmer blade allignment. Need to align the blades correctly so they will cut
ANY SEARS EQUIPEMENT CAN BE LOOKED UP ON SEARS PAERTS.COM
9/11/2017 11:30:40 PM • Craftsman 22"... • Answered on Sep 11, 2017
Why does my craftsman bushwacker hedge trimmers not go fast when I have it full throttle?
if engines stumbling when at full throttle , ck to see that your getting full fuel flow ( lots of bubbles in primer bulb are a sure sign of not a good flow) , locate the fuel filter inside fuel tank , ck it for a dark color ? if so replace it , also try adding some normal car fuel system cleaner to your fuel next time u run it for a few minutes , this helps to loosen stuck deposits inside the carb
6/11/2015 2:11:01 AM • Craftsman 22"... • Answered on Jun 11, 2015
Hedge trimmer runs for a minute and cuts off. Will not start back up immediately. Change spark plug and cleaned carbureator
Could be bad diafram pump on bottom of carb. Looks like a gasket with a metal piece in middle.
5/26/2015 6:54:45 AM • Craftsman 22"... • Answered on May 26, 2015
Dirty carburetor
IF you're right, then you have three options:
  1. Replace carb, or
  2. Remove and overhaul carb [a little expensive and not "fun"],
  3. Try one of those relatively new "in-the-tank" solvent cleaner kits [available at most auto parts stores], but if you do, BE SURE to follow all label instructions "to the letter."
9/12/2014 10:12:33 AM • Craftsman 22"... • Answered on Sep 12, 2014
Blades wont move
Either the gears, OR SOME machines have a "CENTRIFUGAL CLUTCH" [a safety feature] between the engine and the blades. IF your machine has this feature, then it's possible that the clutch has worn out and is slipping so badly that the blade won't move.
9/12/2014 8:40:24 AM • Craftsman 22"... • Answered on Sep 12, 2014
0answers
0answers
Very little gas in pump prime,even after pumping
correct fuel hose to primer?
10/16/2013 1:12:46 PM • Craftsman 22"... • Answered on Oct 16, 2013
0answers
0answers
I have a craftsman 358.796354 hedge trimmer that will start on full choke, throttle in the start position. But, as I move the choke from full it will rev up then stall. The only way I can get it to "r
It sounds like more of a carburetor issue but out of curiosity did they say why they thought it was a compression issue? Although craftsman is a little high on their parts a lot of the aftermarket parts such as a carburetor a lot of times are not all that expensive. I can't imagine you'd have all that many hours on it unless you use it commercially to warrant a compression issue. Might be worth a try.
6/11/2013 10:57:48 PM • Craftsman 22"... • Answered on Jun 11, 2013
Craftsman model 358.796354 quits running after 5min. (coil poss.)
it could be getting the wrong fuel mixture or the engine is getting hot
2/2/2012 4:04:55 PM • Craftsman 22"... • Answered on Feb 02, 2012
Craftsman 22" Gas Hedge Trimmer Logo
105 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
blades wont move
  • Garden
