20 Most Recent
Homelite Consumer Products 7 Amp Blower/Sweeper Questions & Answers
What Octane to use
its better to use the rated octane more often known as "Regular" higher octane will cause damage and could be dangerous
4/2/2010 9:15:03 PM •
Homelite...
Answered
on Apr 02, 2010
Homelite 26 BV Gas Leaf Blower
sounds like you had fuel leak into the cylinder over the winter. The liquid in the cylinder is what made it so hard to pull that first time, as it won't compress like air. What you do, is take the spark plug out, pull the starting rope several times, dry off the spark plug, and let both sit(plug out of the cylinder.) for a couple of hours. Then put the plug back in, put the wire back on it, put it on full choke, and pull until it hits once. Then put it on half choke, and pull til it starts.
3/29/2010 8:16:50 AM •
Homelite...
Answered
on Mar 29, 2010
Need a fuel line diagram for my Homelite vac attack 2 model UT09834
You should have 2 lined coming from tank. A return and feed. Normally the return is the lowest positioned outlet on the carb, and the feed is at the top. When pumping the purge bulb take the gas cap off tank, and you should see fuel being returned to the tank from the return line. If not, switch the lines on carb. If still not returning fuel to the tank, you will need to pull the carb and inspect the metering and fuel pump diaphrams.
What is the spark plug gap for a homelite 2700psi pressure washer with champion eco 322
The recommended spark plug gap for a Homelite 2700 PSI pressure washer with a Champion Eco 322 spark plug is 0.030 inches.
but in my opinion, It's always best to consult the owner's manual or contact the manufacturer for the most accurate and up-to-date information regarding the proper spark plug gap for your specific pressure washer model.
good luck
What gas does a Homelite 16 " Ranger chain saw use
The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle engine oil, and the manufacturer recommends the use of a two-cycle oil that contains fuel stabilizer to keep the mixture fresh if you are not using it immediately.
