20 Most Recent
ECHO, Inc. Shred n Vac Questions & Answers
Echo shred n vac starts,idles, runs to about half power then bogs
Check the grommet that sits on top of tank where lines from go carb. Grommet may be rotten and crack. Try that. Have you ever replace the carb repair kit? The diaphram may be torn, defoam or have holes in them. Carb kit cost arount $10, but don't mess with the welch plug or screen in carb.
Carburettor jet settings
what model Echo? If its a new one with the rotating butterfly then the top is set at 5.5 from closed, and the side is 2.5 from closed., if its the older style then the H setting is one and a half from closed and the L is one and three quarters to start.
Hello,i have a echo es-1000 shred n vac.It will
sounds like a minor adjustment on the high side which is the micture screw to the filter side when it starts to die put the choke on partiallyit should recover breifly which will tell you its a adjustment on the high side
Forgot how tostart it
Ensure you have the correct Fuel / Oil mix for your machine first.
Find the choke knob and turn to the closed position.
Find the Primer Bulb and pump it until it is full of fuel, once the bulb is full give it 3 pumps (If the primer bulb is already full of fuel just give it 3 pumps)
Make sure the ignition switch is in the "I" position and not the"O" position.
Pull start! (should take no more than 3-4 pulls before it fires)
Once it fires it may die instantly.... if so cancel the choke and pull start (should fire again on first pull)
If it does not die and it keeps running, cancel the choke while maintaining the engine's rev's.
Hope this helps.
Vacuum tube will not stay attached. ES 210 sn
Some ES-210 units have been recalled, yes. It does not appear that the recall affects
your particular serial number. However, more info is available from the ECHO-USA website, found
HERE.
If in doubt, use the "
DEALER LOCATOR" link and call your nearest location.
Hope this helps,
Dolf-
Need new bag.
Could you please advise me how much it would cost for a replacement bag for a Shred'n' Vac model ES2100.
Monica Hargrove
Weedeater want reb up put new carburator 230 echo weedeater
I know this is a very old post, but figured I'd answer it so any others with this issue can have the fix.
With Echo trimmers not revving to speed although they start with no problem, the issue is usually the muffler screen. It becomes plugged with carbon because of improperly mixed 2 stroke fuel.
Remove the screen from the muffler and burn off the carbon with a propane torch, or wire brush it off. Once cleaned engine should rev to speed.
6/25/2022 4:53:50 PM •
Echo Garden
Answered
on Jun 25, 2022
