20 Most Recent Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower Questions & Answers
I have a Husqvarna z454 that wont turn on.
Quick an easiest way to isolate the problem whether fuel or spark/compression is with starter fluid (or carb cleaner or flammable brake clean).
To use starter fluid, remove the air filter and set aside. Set throttle low/choke off. Spray a 1 second burst directly into the intake. Leave air filter off and promptly start.
If it fires and runs a few seconds and dies then likely no fuel delivered from carburetor. Remove spark plug, if dry them no fuel delivered from carburetor. Check operation of anti afterfire solenoid, water in carb fuel bowl, other.
If it does not run then either flooded, no spark, or low compression. Remove spark plug. If plug is wet then either too much fuel, no spark, or no compression.
10/8/2023 8:34:04 PM • Husqvarna 26 Hp... • Answered on Oct 08, 2023
2answers
Husqvarna lawn tractor stalls when brake is
sounds like a safety switch most likely the one for your brakes
8/7/2021 9:00:52 PM • Husqvarna 26 Hp... • Answered on Aug 07, 2021
Husqvana raptor 54" - what are tire pressures
https://www.lawnmowerforum.com/threads/is-there-a-best-tire-pressure.31615/ This forum has good information of the correct/best pressure fot the tires.
5/12/2020 3:49:29 AM • Husqvarna 26 Hp... • Answered on May 12, 2020
Poulan pro troubleshooting
Owners Manuals You can download manuals from this site, this may help troubleshoot the problem. Have model number ready.
1/17/2018 7:49:24 PM • Husqvarna 26 Hp... • Answered on Jan 17, 2018
Craftsman mower drive belt falls off when engaging the clutch
Wrong belt or not fitted correctly.
2/5/2016 4:50:30 PM • Husqvarna 26 Hp... • Answered on Feb 05, 2016
Mower starts runs 10 minutes then battery dies. Bought a new battery, however it is still happening. Could it be an alternator?
Yes. Your mower is running directly off the battery
9/18/2015 10:12:27 PM • Husqvarna 26 Hp... • Answered on Sep 18, 2015
What would cause my blades to run slow. The motor runs fine, just the blades are slowing. I cleaned the deck. Just wondering what else would cause that?
I'd check the belt tension. Could be the tension idler arm is sticking or the spring needs to be adjusted.
7/6/2015 8:42:05 PM • Husqvarna 26 Hp... • Answered on Jul 06, 2015
What type of hydraulic oil do you use in a exmark Lazer z zero turn lawnmower?
Exmark Premium Hydro Oil. I was not able to find a cross reference.
4/27/2015 4:37:18 PM • Husqvarna 26 Hp... • Answered on Apr 27, 2015
How do you check the hydulic oil on the mower
You didn't give the model number but from the manual I read it is sealed. "the transmission is maintenance free with no need for level checks or oil changes. If a leak occurs, replace the unit or contact your Husqvarna dealer" http://www.husqvarna.com/ddoc/HUSO/HUSO2010_USen/HUSO2010_USen__115384327.pdf
7/21/2014 3:59:32 AM • Husqvarna 26 Hp... • Answered on Jul 21, 2014
Unable to find the Troybilt deck V belt that fits my 2002
If it's the belt that just runs on the deck and not the one that goes to the engine, it is a 954-0349
3/5/2014 8:43:05 PM • Husqvarna 26 Hp... • Answered on Mar 05, 2014
Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower Logo
70 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
z454 wont turn
  • Garden
