20 Most Recent Craftsman 26 Hp 54" Deck Yard Tractor Questions & Answers
2answers
Parts manual for sears dgs 6500 tractor
check with SearsPartsDirect
2/2/2018 4:23:52 PM • Craftsman 26 Hp... • Answered on Feb 02, 2018
Rest hour/service meter on 24hp sears tractor
There is not a reset on the meter. The meter will automatically reset after 6 - 8 hours of use.
1/2/2018 8:05:34 PM • Craftsman 26 Hp... • Answered on Jan 02, 2018
Deck Height Adjusting
you should have holes on the arms of the adjuster look for the most worn hole that is where the studs should go
12/30/2017 4:14:27 PM • Craftsman 26 Hp... • Answered on Dec 30, 2017
I have a 2007, 6500
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
6/11/2017 6:48:51 PM • Craftsman 26 Hp... • Answered on Jun 11, 2017
Runs fine until engage hdro.transmission ,then wants to die
Hi Randy, The 1st video link below shows a craftsman mower with the same problem and the 2nd video shows a probable solution... I hope this helps....CHEERS.. https://www.youtube.com/watch?v=-I5CBD_7nQw https://www.youtube.com/watch?v=Xi3p465MN1E
4/4/2016 11:17:06 PM • Craftsman 26 Hp... • Answered on Apr 04, 2016
How can you check to make sure the governor is working on a 26hp kohler engine?
check and clean area around governor lever, check for free movement, press the helpful button and check link below Small Engine Repair How to Adjust the Mechanical Governor on Kohler Twin...
1/13/2016 5:19:34 PM • Craftsman 26 Hp... • Answered on Jan 13, 2016
How to install a 54" deck on a 24 hp craftsman lawn tractor?
Please provide model number of mower.
9/22/2014 7:06:27 AM • Craftsman 26 Hp... • Answered on Sep 22, 2014
Craftsman tractor mower deck doesn't go up or down
Make sure lift lever is connected properly and adjusted.
7/21/2014 7:36:49 PM • Craftsman 26 Hp... • Answered on Jul 21, 2014
What should I do; I have a craftsman 26 hp 54" deck yard tractor that will click but will not start?
Test starter by using jumper cables from negative pay on battery to a good ground (bare metal on the frame somewhere) and positive post to starter post ( should be a thick red wire attached to starter post. Be careful because the starter will turn bypassing all safeties. You should have the key off, parking brake on, blades disconnected. If starter turns, starter is good.
7/6/2014 5:16:58 AM • Craftsman 26 Hp... • Answered on Jul 06, 2014
3answers
Toro LX500 CH 6 oil light went on and will not go off
Hey Jamie..im pretty sure that light means its time to change the oil..and when you do change the oil..reset the counter..i hope this has helped
6/5/2014 5:38:42 PM • Craftsman 26 Hp... • Answered on Jun 05, 2014
Blades won't enGage motor dies
First unplug the plug wires, take key out of switch, then check to make sure that the blades will move by hand. there could be a dirt mound or rock jammed in there
6/3/2014 5:44:36 AM • Craftsman 26 Hp... • Answered on Jun 03, 2014
0answers
Belt diagram
search for your model # (should be able to find it on label under seat). You should be able to find users manual on sears site. This will have belt diagram for both drive and deck belts.
5/16/2014 8:48:45 PM • Craftsman 26 Hp... • Answered on May 16, 2014
Craftsman 26 Hp 54" Deck Yard Tractor Logo
148 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
runs fine until engage hdro transmission
  • Garden
