20 Most Recent
Ariens 34 In. Zoom Series Riding Mower Questions & Answers
I have an ariens zoom 1540 hydrostatic mower. One
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered.
Square dimension for one acre
One acre is about 4047 square meters or about 43,560 square feet. For a square plot of land, that's about 61.62 meters or about 208.7 feet on a side.
How to relace drive belt on ariens tractor a20va46?
There are multiple belts on the Ariens A20VA46 lawn tractor. Which belt are you asking about?
Service and Owner's manuals can be downloaded from the following link:
Find Manuals by entering your tractor's model and serial numbers.
The deck drive belt is easy to change by releasing spring pressure on the idler pulley (usually under a plastic cover). See the user's or service manual for directions from the above link.
The two transmission belts are somewhat more difficult, but are usually long-lasting. The newer type of continuously variable transmissions used on these tractors have a friction belt like a snowmobile but under much less load. As a result, they are long-lasting. The engine to transmission belt is a conventional V-belt and may require occasional replacement. Usually, there's a similar tensioner pulley you would release in order to replace this belt.
Why won't the blades engage on my Ariens 911403
Chances are the deck drive belt has been knocked off one of the pulleys or the drive clutch won't engage properly. With the spark plug wire removed, rotate the blades by hand and make sure they both move together. This verifies the blade linking belt is OK. Now engage the blade operating control and feel for resistance as you rotate the blades. If you feel no change in resistance, remove the belt cover and reinstall the drive belt over the pulleys and tensioner/clutch mechanism.
