20 Most Recent
Mantis Tiller Questions & Answers
What is optical illusion
http://en.wikipedia.org/wiki/Optical_illusion
http://illusionsetc.blogspot.com/
this materiel is very helpful for u
must rate me high.
Mantis tiller no spark
Hi anon two thing's that it could be. Firstly it could be the coil is fouled by Corrosion or secondly the switch that you switch on could have failed.
Why won't my ryobi ry13010 not be getting fuel
possible fuel gel condition, add Stabil to gas. This dissoves gel that forms from sitting for long periods. Also check fuel lines for breaks or cracking. Check bubble pump for leaks and cracks.
When I Start Mantis Tilleer it starts in gear (
The Mantis has a speed controlled automatic clutch.
Lower the idle speed by turning the idle screw counter clockwise. The idle screw is attached where the throttle cable meet the carb. The screw has a pointed end that resembles a pencil point.
The engine speed should be adjusted just above stalling.
If the tines turn even when the engine pull rope is pulled, the the clutch is defective and needs repairing.
j
