20 Most Recent
Hitachi Magic Wand Hv250r Hand Held Massager Questions & Answers
The small spring inside my
Super easy fix. The drive spring gets twisted when bearing in vibrating head seizes due to moisture. Spray wd40 on the seized bearing and reinforce the spring drive with a pickup stick down the center. Happy wife happy life.
What do I do if my Hitachi Magic Wand appears to be burnt out?
The drive spring gets twisted when bearing in the vibrating head seizes due to moisture. Spray WD40 on the seized bearing and reinforce the spring drive with a pickup stick or chopstick down the center.
Any rod that fits snugly inside the drive spring will do.
(credit to YouTube commenter oo ee)
Sounds like its working, but nothing happens
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up
and down. Now, you need to use a utility knife and cut the blue rubber
off of the spring. Once you have the blue rubber but off you can see a
large spring with another smaller spring inside. Push the head of the
******** till the larger spring's coils are an 1/8 to 1/4 of an inch
apart. Next take either the small slot head screw driver or a pair of
needle nose and jam the smaller spring back into the hole in the center
of the white plastic piece inside of the larger ring. Next plug it in
to make sure the vibration is working, reattach the silver piece and
tape the larger spring with electric tape.
