20 Most Recent Leeson Reversible Electric Motor 3/4 HP Questions & Answers
2answers
My boat lift electric moter was replaced... it now
check input voltage check to see if its the proper phase check tension on belts, gear, or connection from motor
3/5/2015 8:58:02 PM • Leeson... • Answered on Mar 05, 2015
I have Delco Model 2J2424r1, frame 56R, Series
If it has 9 leads and is a 240/480 volt motor the 1and 7 go to line 1. the 2 and 8 leads go to line 2 and the 3 and 9 leads go to line 3. the 4 5 and 6 leads are hooked together with a wire nut. To reverse rotation simply reverse any 2 of the line leads.. Prairie Dog........
11/15/2012 12:07:18 AM • Leeson... • Answered on Nov 15, 2012
What happens to a 240v
It will not run. With only one wire hooked to both leads there is no potential and no place for the current to flow to. electric bruno.
6/17/2011 3:36:15 AM • Leeson... • Answered on Jun 17, 2011
I have a 3/4 HP motor installed on my porch
it is possible that the start/run winding is open cicuit or cable connections via the capacitor you mentioned , is it distorted , any sign or leakage . as it is on a stair lift the motor has to be reversed , is the reversing switch intact.
Ian c
1/27/2010 8:43:45 PM • Leeson... • Answered on Jan 27, 2010
I need a diagram to wire it to a saw
should be a wiring diagram on the wiring cover.
10/26/2009 1:03:22 PM • Leeson... • Answered on Oct 26, 2009
I have an Inca 343.190 planer / thicknesser with a problem: the in-feed and out-feed tables are not parallel, but I can't find any advice on how to adjust these tables. Can anyone help please?
The best resources to answer this would be the maker themselves, or the woodworking / machine forums. Details in the link. https://www.google.com/search?q=inca+343.190+manual
Automatic Planer jointers thicknesser 343.190 - Inca Parts ...
Incamachines https://incamachines.com > english > inca-spare-parts > a... 343.190 planer thicknesser plane jointers US models 510, 550, 570.
INCA Woodworking Jointer Planer
Machine Atlas https://docs.machineatlas.com > Inca+Woodworki... PDF The INCA Woodworking. Machinery Handbook. With useful tips and jigs for everyone. Mark Duginske, Karl Eichhorn. ????. Edited by INCA Ltd, Teufenthal/Switzerland . ..
4/19/2024 7:07:51 PM • Tools & Hardware... • Answered on Apr 19, 2024
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
3/18/2024 5:15:05 AM • Tools & Hardware... • Answered on Mar 18, 2024
Vibrapower Disc model BW-5040 exercise machine. E4 flashing on a Vibrapower disc model 5040. Replaced power cable
Question edited for clarity and typos. Question moved from Office Equipment category. It appears to be an unknown machine with no support and only mentions of people selling them. https://www.google.com/search?q=vibrapower+disc+5040+E4+error https://www.google.com/search?q=vibrapower+disc+BE-5040 A manual will often lead the the maker. https://www.google.com/search?q=vibrapower+BE-5040+manual ..
2/2/2024 1:34:19 AM • Tools & Hardware... • Answered on Feb 02, 2024
2answers
Where can I get replacement parts for my Tradesman BD460VM belt sander?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=Where+can+I+get+replacement+parts+for+my+Tradesman+BD460VM+belt+sander%3F
12/5/2023 10:35:53 PM • Tools & Hardware... • Answered on Dec 05, 2023
2answers
How to load a black and decker staple gun model dn418/d16
What width staples go in this gun ?
I have a box of T50 staples here labeled 5/16 , 8mm, but they are too narrow when dropped in to the channel in the stapler.
11/12/2023 6:22:42 PM • Tools & Hardware... • Answered on Nov 12, 2023
Leeson Reversible Electric Motor 3/4 HP Logo
17 questions posted
Top Leeson Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Leeson Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Leeson Tools & Hardware - Others
Most Popular Question
boat lift electric moter replaced now
  • Tools & Hardware - Others
