20 Most Recent Black & Decker 11A 1 Router Questions & Answers
Go to this link and download the PDF file. You'll be routing the shapes of your dreams in no time at all. Pantograph manual.
Incidentally, you can get a manual for the router at the same site, by going to the home address and inputing your model number.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Black & Decker... | Answered on May 18, 2013
Nearly all routers have a locking pin that you depress to lock the rotor then you should have a set of wrenches that came with the unit to loosen the mandrel and release the bit. Then just reverse the process to install the new bit.
Black & Decker... | Answered on Jun 26, 2011
go to Dewaltservicenet.com and type in your model number and it willl ask for the type number and you can download a manual and also a breakdown for this tool. they also have a locator for local vendors who carry their product.
Black & Decker... | Answered on Jan 09, 2011
i have found that most times there is a slight bit of rust on the bit
buff it down with some 150 paper,and also buff inside the collet
Black & Decker... | Answered on Aug 22, 2010
If you are doing freehand routing, you need bits with a ball bearing on the end to track the un-machined edge of the work. Other complicated designs require some form of 'jig' or fence that controls the position of the bit. If you didn't receive an owner's manual with your bequest, it would be helpful to find some good how-to manuals at specialty wood-working stores which also give you ideas for projects, making jigs, using a router table, and other useful information. Use a decent respirator and safety glasses when routing as they produce prodigious amounts of fine wood dust. Don't smoke while using the router as the dust in the air is quite explosive if ignited. The pictures in these manuals show how the router is mounted in the table and how to use it properly. The bits that you use must be very sharp to make clean cuts without also making smoke. Hope you find this useful!
Black & Decker... | Answered on Dec 21, 2009
the third standard handheld collet size is 8mm (thank the germans for that). you could either get a new 8mm collet for the router or for cheaper get a 1/2" to 8mm reducing sleeve from a good tool stockist or ebay... the sleeves are unversal. the collets are not...
good luck
Black & Decker... | Answered on Oct 23, 2009
https://www.ebay.com/itm/BLACK-DECKER-TYPE-2-STAPLES-14MM-B-D-A5918-BD418-DN418-5-PACKS/323540126977?hash=item4b547e8d01:g:scoAAOSweW5VLsTQ:rk:3:pf:0
Black & Decker... | Answered on Nov 14, 2018
They don't have an instruction manual online at the Black and Decker support site, but if you want a look at the exploded diagram, it's here.
Basically there's a collet nut that gets tightened down to hold the bit in place. You've got to loosen it up and you'll be able to pop bits in and out. You've got to have some way to lock the shaft while you're doing this though.
Most modern routers have a spring loaded shaft lock button. While you're holding it in, start turning the collet. When the shaft gets to the point where there's a little hole for the spring lock, you'll probably hear a little click, and the shaft will be locked so you can loosen the collet. If you take your finger off the shaft lock, it pops right back out again so hold it down while you're loosening and tightening.
If you don't see a shaft lock button, you may have a second hex nut at the base and with two wrenches, you can hold the hex nut and turn the collet loose that way.
If this answer was helpful, please give it a vote. Thanks.
Black & Decker... | Answered on Oct 25, 2018
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
Black & Decker... | Answered on Mar 10, 2018
The voltage dip followed by a surge caused it to fail.
Black & Decker... | Answered on Dec 25, 2017
Black & Decker 11A 1 Router Logo
15 questions posted
Top Black & Decker Tools & Hardware - Others Experts
James Ryan
Level 1 Expert
mark gardner
mark gardner
Axel Gringmuth
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Tools & Hardware - Others
Most Popular Question
broke plastic base
  • Tools & Hardware - Others
