20 Most Recent Hitachi H60MRV Sds Max Demo Hammer Questions & Answers
Try just stopping and starting the machine off a while.to see if the hammer appears.
Hitachi... | Answered on May 03, 2014
There is a sight glass on the side for you to see the oil level. Make sure they are always checked. You can buy the oil at any service center. Hilti makes oil too and can probably be purchased at Home Depots. Also the Home Depots that have tool rental programs would most likely sell the Hitachi oil too.
Hitachi... | Answered on Apr 24, 2012
For most climates a good oil to use is air compressor oil (mineral). Sold at Lowes and many other stores. It has great lubrication properties and can take good amount of heat. In very cold climates where oil could thicken, store hammer indoors to keep warm until ready to use. Good luck
Hitachi... | Answered on Jul 01, 2011
Hitachi sells a pneumatic oil for use in its air power tools. Your local Hitachi dealer, or any pneumatic dealer will sell the oil. The brand is not as important as using a few drops directly into the air fitting when starting a day of work. If used heavily, oil it again mid way through the working day.
Hitachi... | Answered on Jan 26, 2010
3 to 4 ounces for first fill. You actually unscrew the oil gauge with the little wrench that should have come with the tool and add the oil there. After putting the cap back on, hold the tool upright to check the oil level. Check daily and add oil when the level drops to 1/4 when checking as described above.
Hammering | Answered on Apr 05, 2019
kango 950 was the hammer drill version. Usually when they stopped hammering they were due for a rebuild. These units have a aluminum piston that rides in a steel tube striker. When the 2 rubber piston rings wear out you will get the described problem. The Kango's use a special tan grease so you cannot just yank it apart and replace the 2 rings with o-rings and grease. I had to rebuild 15 900 and 950's because the previous mechanic used the wrong grease. https://project21designs.com/kango-950-parts
The link sells grease & rings.
Hammering | Answered on Mar 13, 2019
You need to check armature gear it can be damaged. Connection rod can be broken or you just need new o-rings and grease
Hammering | Answered on Feb 09, 2019
Buy a new switch the old switch was modificated by an maintenance kit if you have an old blue or red real Kango from England. or black Atlas Copco .
But if you have the red Milwaukee Kango then there is only a new switch to replace.
Hammering | Answered on Aug 28, 2018
  1. The total condition of the seal anvil piston and striker are very important for the total condition of impact when spending a service kit (maintenance) when there is leakage at the front part everything will be hot inside and the rings will harden again quickly.
kango 900 950 round switch housing
Hammering | Answered on Aug 16, 2018
Hitachi H60MRV Sds Max Demo Hammer Logo
0 questions posted
Top Hitachi Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
ray gallant
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
View Most Popular
Hitachi Hammering
  • Hitachi Hammering
Most Popular Question
kind oil
  • Hammering
