20 Most Recent
Pride Mobility Legend 4 Wheel Electric Scooter Questions & Answers
We had a technician put two new batteries on the
To find out if your original charger is working properly, You will need access to a volt/ohm meter. Or you can use a test light ( a 12vdc light bulb with a wire and a paper clip will work in a pinch). Plug in the Original charger - using a volt meter (or a test light) Check for voltage on the tip of the charger that plugs into the receptacle on the scooter. Check the tip with your meter, one probe in the center hole and the other probe on the outside collar. You should read approx 26vcd. If you do not get a voltage reading, wiggle the cord around to see if it is damaged inside. If you get a reading that jumps around you have a bad cord. Try to find the break and if it is not to close to the tip it can be repaired. If you do not get a reading at all, the charger may be bad. In that case, cut the end off and use the other charger your husband used, hook it to the wires on the cut off tip and charge the battery's that way through the normal port so you do not have to remove the panels to access the battery's for charging. If you do not find anything wrong with the charger or the wire plug. Check the connections from the charging port receptacle to the battery's, one of the wires may have broken off in-between. Hope this helps Fixya up. .
Pride Zero Turn 10 - 4 beep code randomly while driving.
It is called the "current limit time out." Apparently the battery needs to recuperate or adjust its charge across the cells. That is another question. What it needs is a few minutes to be turned off. I know this from seeing the manual.
https://youtu.be/PB2JsjU9m3A?si=QEXCzBoW3ni5mWyi&t=122
St Anthony's Nursing And Rehabilitation Center
St. Anthony's Nursing and Rehab Center is a leading provider of compassionate, high-quality healthcare services dedicated to enhancing the well-being of our residents. With a rich history of delivering exceptional care to seniors and individuals in need of rehabilitation, our facility is a cornerstone of the community. At St. Anthony's,we believe in the power of personalized care, combining cutting-edge medical technology with a warm, family-oriented approach. Our experienced and dedicated team ensures that each resident's unique needs are met, providing a comfortable and nurturing environment for their journey to recovery. We take immense pride in offering a brighter and healthier future to those we serve, embodying our commitment to exceptional healthcare. Source: https://sanrc.com
Where is the fuse on my Jazzy pride mobility scooter
the fuse box location may vary depending on the model of the scooter. However, it is usually located under the seat of the Jazzy scooter. You can access it by unscrewing the two bolts that hold the seat in place. Once you remove the seat, you should see a black box with a white label that says "FUSE". The fuse is located inside this box.
The latch won't stay latched on pride jet 3 ultra
If the latch on your Pride Jet 3 Ultra power wheelchair won't stay latched, there are a few potential causes and solutions you can try:
- Check for obstructions: Inspect the latch mechanism and the surrounding area for any obstructions or debris that may be preventing it from latching properly. Remove any obstacles and ensure that the latch can move freely.
- Adjust the latch position: Sometimes, the latch may need to be adjusted to ensure a proper fit. Check if there are any adjustable components on the latch mechanism and try repositioning them to achieve a secure latch.
- Tighten or replace the latch: If the latch is loose or worn out, it may not hold securely. Check if there are any screws or fasteners that can be tightened to secure the latch. If tightening doesn't solve the issue, you may need to replace the latch with a new one.
- Seek professional assistance: If the latch continues to have issues or you are unsure about making adjustments or replacements yourself, it's best to contact Pride Mobility or a certified technician for further assistance. They will have the expertise to diagnose the problem and provide the appropriate solution.
