20 Most Recent Dewalt 3" X 21" Belt Sander Questions & Answers
0answers
Stopped working might have overheated it does
have you checked the fuse first.
possibly worn brushes on the motor, remove the brushes and check the length of them , also look to see if they are pitted or burned.
7/18/2009 7:07:20 AM • Dewalt 3" X 21"... • Answered on Jul 18, 2009
DeWalt planer leaving little gouge marks on the board. Recently had a new chain installed. Any help would be greatly appreciated.
It needs new blades - likely has a chip in one. See link for replacement tutorial
6/14/2022 4:37:07 PM • Dewalt Tools &... • Answered on Jun 14, 2022
Dewalt dc618 nail gun won't shoot
https://www.weeklytools.com/dewalt-angle-grinder-buying-guide/ When it comes to Angle Grinder, the name of the Dewalt tools maker comes first. We will look at the basic parts and functions of a grinder before purchasing a machine. Then let's see the details without delay.
3/13/2021 8:23:58 PM • Dewalt Tools &... • Answered on Mar 13, 2021
How do you change blades on DeWalt DW50 planer
https://www.weeklytools.com/different-uses-for-an-angle-grinder/ An angle grinder is a multifaced handheld power tools that was invented by a German company. We may don't know a lot about this tool because it is an unrecognized instrument like some other tools. Now we will discuss different Uses for angle grinder. An angle grinder is also known as a side grinder or disc grinder. It is a machine with a rotating abrasive cutting disc. Angle grinders can be powered by an electric motor, petrol engine, or compressed air. It comes in a wide variety of different sizes and powerful motor, each with the other purpose. Once anyone knows about these, he can easily find out the best angle grinder for his needs. Angle grinders are quality fulled equipment for any metal fabrication shop, and those are typically used in auto repair, workshops, and construction sites.
3/13/2021 8:22:33 PM • Dewalt Tools &... • Answered on Mar 13, 2021
Model DC618 nail gun. Why does it start, then shuts down as soon as I depress to fire nail?
https://www.weeklytools.com/how-to-use-a-nail-gun-with-an-air-compressor/ We may not need a drill machine almost the whole time. But there is a demand for a pilot hole during the home finishing process. This post is not for you if you are a professional. However, in most of the cases, we observe the necessity for a pilot hole. From wooden doors and windows ...
3/11/2021 9:28:06 PM • Dewalt Tools &... • Answered on Mar 11, 2021
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
2/3/2021 5:13:02 PM • Dewalt Tools &... • Answered on Feb 03, 2021
My dewalt 1223 brad nailer will not fire
The nailer must be firmly pressed against the surface you are planning to nail. This will arm the nailer in preparation for firing the nail.
10/3/2019 9:15:00 PM • Dewalt Tools &... • Answered on Oct 03, 2019
Speed control wire around on DW423 sander
Try this link: https://www.ereplacementparts.com/dewalt-dw423-type-inch-evs-random-orbit-sander-parts-c-1009_2742_2758.html
4/2/2019 10:42:12 PM • Dewalt Tools &... • Answered on Apr 02, 2019
Changed blades on 733 dewalt planer now rollers not working could it be associated chews up broards
Either the blades are incorrectly installed causing the head to jam or the safety cover is not installed properly - there is a safety mechanism that locks the cutter head when the cover is removed.
2/2/2019 6:38:10 PM • Dewalt Tools &... • Answered on Feb 02, 2019
Dewalt 3" X 21" Belt Sander Logo
8 questions posted
Top Dewalt Tools & Hardware - Others Experts
john h
Sean Wright
Sean Wright
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Tools & Hardware - Others
Most Popular Question
stopped working might overheated r nit
  • Tools & Hardware - Others
