20 Most Recent Black & Decker 4.3A 6" Heavy Duty Right Angle Random Orbit Sander Questions & Answers
I have a type 2,#92 heavy duty sander,length of
First try Black & Decker Serves Department. At some Hardware stores (ACE, True Value, etc)they stock brushes in the back room.
6/12/2009 2:17:53 PM • Black & Decker... • Answered on Jun 12, 2009
I am looking for a manual or parts list for a black and decker U-140 Sander
its listed as a vintage sander may have to source used ones ... ebay ? cant find a user manual online parts might be discontinued not showing up on the parts list Black and Decker Sander Parts 26331537-vy1lstfh3l30zusxkpzc2uyh-1-0.jpg
2/28/2024 6:16:06 PM • Black & Decker... • Answered on Feb 28, 2024
2answers
Aguired a black and decker model 7600 router tool.
They don't have an instruction manual online at the Black and Decker support site, but if you want a look at the exploded diagram, it's here.
Basically there's a collet nut that gets tightened down to hold the bit in place. You've got to loosen it up and you'll be able to pop bits in and out. You've got to have some way to lock the shaft while you're doing this though.
Most modern routers have a spring loaded shaft lock button. While you're holding it in, start turning the collet. When the shaft gets to the point where there's a little hole for the spring lock, you'll probably hear a little click, and the shaft will be locked so you can loosen the collet. If you take your finger off the shaft lock, it pops right back out again so hold it down while you're loosening and tightening.
If you don't see a shaft lock button, you may have a second hex nut at the base and with two wrenches, you can hold the hex nut and turn the collet loose that way.
If this answer was helpful, please give it a vote. Thanks.
12/20/2023 10:50:18 PM • Black & Decker... • Answered on Dec 20, 2023
2answers
What does the code F02 mean for a smart battery charger
It means one of two things. Either you do not have a good connection from the charger to the battery, check and clean the clamps and terminals, or the battery has too low a charge. A smart charger needs to measure the existing charge before it will work.
11/10/2023 5:57:51 PM • Black & Decker... • Answered on Nov 10, 2023
Staples for dn418/d16 black and decker staple gun
Try this place. https://www.my-staple.com/articles/agrafes-pour-black-decker-dn418-473.html?lg=en
4/26/2022 10:58:09 AM • Black & Decker... • Answered on Apr 26, 2022
Can I use the heat element of a 1000W blow dryer in a 1000W heat gun?
Yes, the difference is the air flow over the 1000 watt element, blow dryer, uses lots of air, heat gun uses a lesser airflow.
10/8/2021 6:00:12 PM • Black & Decker... • Answered on Oct 08, 2021
2answers
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
3/10/2018 7:47:06 AM • Black & Decker... • Answered on Mar 10, 2018
Where can I buy staples for B&D model 9700-04
You should be able to find them at your local hardware or Menards store. I worked at a True Value store and we had them there.
12/23/2017 12:50:02 AM • Black & Decker... • Answered on Dec 23, 2017
2answers
Belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
12/31/2016 3:57:01 PM • Black & Decker... • Answered on Dec 31, 2016
Dewalt dw9118
First I question what's the charger doing for whatever you are charging or is it charging? I would say if the only problem is a hum and all else is OK then don't worry, let it be.
10/2/2016 6:42:30 PM • Black & Decker... • Answered on Oct 02, 2016
Black & Decker 4.3A 6" Heavy Duty Right Angle Random Orbit Sander Logo
1 questions posted
Top Black & Decker Tools & Hardware - Others Experts
Paul Carew
Accurate TV Repair...
john h
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Tools & Hardware - Others
Most Popular Question
type 2 92 heavy duty
  • Tools & Hardware - Others
