20 Most Recent Epiphone Dot Electric Guitar Questions & Answers
Need to replace the amp jack nut, Epiphone Dot
Just take the guitar with you to a local guitar music store, where you'll have to go anyhow to get the part, and the store will be happy to repair it for
the price of the part.
8/28/2018 5:18:29 PM • Epiphone Dot... • Answered on Aug 28, 2018
Truss rod slippage
If the truss rod has broken loose, it is not user serviceable. This needs to go to a repir shop. The fretboard has to come off to fix this. The repair may be more than the value of the guitar.
1/2/2015 7:47:39 PM • Epiphone Dot... • Answered on Jan 02, 2015
Wiring diagram
http://www.gibson.com/Files/schematics/Dot%20Studio%20wiring.pdf
1/8/2014 6:08:08 PM • Epiphone Dot... • Answered on Jan 08, 2014
I bought a used Epi
It sounds like your selector switch might be faulty. Here is the diagram:http://www.gibson.com/Files/schematics/Dot%20Studio%20sch.pdf
11/16/2010 1:17:33 AM • Epiphone Dot... • Answered on Nov 16, 2010
Hello I bought an Epiphone
The serial number SHOULD be stamped on the back of the head above the farthest tuner. It is like an eleven digit number.
It is POSSIBLE if your unit does NOT have this that it is counterfeit... it is happening all the time now.
10/30/2010 2:26:16 AM • Epiphone Dot... • Answered on Oct 30, 2010
How do I fix the high action on the dot?
First, try lowering the bridge. Lower it as ow as you can without the strings buzzing excessively. Check the straightness of the neck. You can adjust the truss rod and put a very slight bow in the neck if low action results in too much string buzz in your case. The nut may also be too high but a simple bridge adjustment should do it.
12/16/2009 4:39:38 PM • Epiphone Dot... • Answered on Dec 16, 2009
Plug-in jack fell inside body of epi dot
jus take the roof bracket off the scratchplate and you can push it back out with some copper wire ! happened to me twice lol
10/25/2009 2:23:17 AM • Epiphone Dot... • Answered on Oct 25, 2009
Try to see if you can fish one of the wires attached to the jack out enough to get the jack through the F hole. If you can get to the jack, get some medical tubing ( like they use in sling shots for example ) that will fit inside a jack. Stick the medical tubing through the guitar starting at the outside of the hole the jack is supposed to be in. Once you can fish the end of the tubing out through the Fhole, insert it into the jack and gently and carefully manuever the jack back into position by pulling on the other end of the tubing. You should be able to slide the washer and then the nut down over the tubing until you can thread them back into -place. Hope this helps.
10/23/2009 1:48:46 PM • Epiphone Dot... • Answered on Oct 23, 2009
Was playing at high volume, immense air pressure
which is broken the electric guitar? or the amp?
8/12/2009 9:10:59 PM • Epiphone Dot... • Answered on Aug 12, 2009
I need a manual for epiphone ES335 Dot Archtop
Guess what there is no manual for your Epi, just ask the ? there are not many you could ask . Guitars are parity strate forward beyond any warren tee , you don't get much info on any gtr.
4/11/2009 6:10:06 PM • Epiphone Dot... • Answered on Apr 11, 2009
Epiphone MM-50E Professional Mandolin. Parts list for Epiphone MM-50E Professional Mandolin to order a new pickup/volume control please.
Question edited for clarity and toss in some CAPS. Your local Music Shop, or a local Lautist. No one is listing parts. https://www.google.com/search?q=epiphone+mm-50e+mandolin+parts+list Generic Mandolin pickup https://www.google.com/search?q=mandolin+pickup ..
10/16/2023 12:35:32 AM • Epiphone Music • Answered on Oct 16, 2023
Epiphone Snakepit 15G Amp
This is for the 15R, but page 1 has the phone number. Call and ask. https://www.manualslib.com/manual/996936/Epiphone-Electar-15r.html#manual And you are right, there is no manual. This search query is crafted to find that model specifically. https://www.google.com/search?q=%22epiphone+snakepit+15G%22+manual ..
7/10/2023 4:26:19 PM • Epiphone Music • Answered on Jul 10, 2023
2answers
Can you tell me about my 'Epiphone Special Custom Shop'? The serial number is 1107132830
9/6/2022 5:22:45 AM • Epiphone Music • Answered on Sep 06, 2022
Epiphone ET-280 Bass Guitar. Wiring diagram for it please?
Question edited for clarity. It doesn't appear online. Try one of the specialist guitar forums. https://www.google.com/search?q=epiphone+bass+et+280+wiring+diagram ..
8/22/2022 6:51:25 PM • Epiphone Music • Answered on Aug 22, 2022
Can you tell me anything about my Epiphone FR25 81801?
Your guitar was made at the Kalamazoo Plant, MI, USA between 1962 and1964, most likely in 1962.
8/2/2020 10:39:04 AM • Epiphone Music • Answered on Aug 02, 2020
Slash Epiphone Special 2 Shadow tuner lights up but doesnt work
https://www.youtube.com/watch?v=Fq6J6ufH9uk https://www.youtube.com/watch?v=cZXT8RE_Xqg
3/22/2020 4:52:51 PM • Epiphone Music • Answered on Mar 22, 2020
Epiphone I6070236 where is it made? What is it worth?
Korea, 1996, July as best as I can make out from https://forum.gibson.com/topic/139846-epiphone-serial-number-decoding/ without knowing the model and the condition, there's no telling what it's value is. Check reverb.com for similar guitars safe to say tho that a Korean made Epiphone is not a classic (pre-Gibson) and will not be a high value guitar.
11/2/2019 4:49:54 AM • Epiphone Music • Answered on Nov 02, 2019
2answers
What Epiphone model did I purchase?
Sounds like perhaps a Les Paul Special II, but more detail is needed to say for sure. There was a lot of variation in their Les Paul models. Posting a photo of both sides and the headstock is best. -Has the guitar any binding, and what colour? -Is the back of the guitar white or all black? -Exactly what is on the front of the headstock, 'Epiphone', the 4-diamond logo, anything else? .
9/11/2019 8:32:39 AM • Epiphone Music • Answered on Sep 11, 2019
2answers
Epiphone volume and tone controls
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls:
http://www.guitarelectronics.com/product/WDUHH3T2202
9/11/2019 8:29:01 AM • Epiphone Music • Answered on Sep 11, 2019
Epiphone Dot Electric Guitar Logo
Popular Tags
15 questions posted
Top Epiphone Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
tednugentlives
tednugentlives
Level 1 Expert
Are you an Epiphone Music Expert? Answer questions, earn points and help others
View Most Popular
Epiphone Music
  • Epiphone Music
Most Popular Question
bought used epi
  • Music
