20 Most Recent
Aquabot Robotic Pool Cleaner Questions & Answers
Pump keeps burning up
The problem might be lost contact or incorrect wirings. Try to contact your service provider about it.
My aquabot does not reverse
check with the website: http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Aquabot-Troubleshooting.html which gives a wealth of information and ideas to try. S. Christian
[email protected]
My aqua bot will not move
Check and make sure that there is no debis in the drive belts! If you are near Phoenix AZ I my be able to look at it with you. Also, the website http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Aquabot-Troubleshooting.html may be useful to look at S, Christian
[email protected]
Stops moving
This points to a circuit board defect. Authorized service center only, unfortunately
Calculator in java
<FORM NAME="CALCULATOR">
<TABLE BORDER=4>
<TR>
<TD>
<INPUT TYPE="text" NAME="Input" Size="16">
<br>
</TD>
</TR>
<TR>
<TD>
<INPUT TYPE="button" NAME="one" VALUE=" 1 " OnClick="Calc.Input.value += '1'">
<INPUT TYPE="button" NAME="two" VALUE=" 2 " OnCLick="Calc.Input.value += '2'">
<INPUT TYPE="button" NAME="three" VALUE=" 3 " OnClick="Calc.Input.value += '3'">
<INPUT TYPE="button" NAME="plus" VALUE=" + " OnClick="Calc.Input.value += ' + '">
<br>
<INPUT TYPE="button" NAME="four" VALUE=" 4 " OnClick="Calc.Input.value += '4'">
<INPUT TYPE="button" NAME="five" VALUE=" 5 " OnCLick="Calc.Input.value += '5'">
<INPUT TYPE="button" NAME="six" VALUE=" 6 " OnClick="Calc.Input.value += '6'">
<INPUT TYPE="button" NAME="minus" VALUE=" - " OnClick="Calc.Input.value += ' - '">
<br>
<INPUT TYPE="button" NAME="seven" VALUE=" 7 " OnClick="Calc.Input.value += '7'">
<INPUT TYPE="button" NAME="eight" VALUE=" 8 " OnCLick="Calc.Input.value += '8'">
<INPUT TYPE="button" NAME="nine" VALUE=" 9 " OnClick="Calc.Input.value += '9'">
<INPUT TYPE="button" NAME="times" VALUE=" x " OnClick="Calc.Input.value += ' * '">
<br>
<INPUT TYPE="button" NAME="clear" VALUE=" c " OnClick="Calc.Input.value = ''">
<INPUT TYPE="button" NAME="zero" VALUE=" 0 " OnClick="Calc.Input.value += '0'">
<INPUT TYPE="button" NAME="DoIt" VALUE=" = " OnClick="Calc.Input.value = eval(Calc.Input.value)">
<INPUT TYPE="button" NAME="div" VALUE=" / " OnClick="Calc.Input.value += ' / '">
<br>
</TD>
</TR>
</TABLE>
</FORM>
eNJOY
How to replace wheel tubes on aquabot bravo III
To replace the wheel tubes on an Aquabot Bravo III robotic pool cleaner, follow these steps:
1. Prepare the Pool Cleaner: Turn off the power to the pool cleaner and remove it from the water. Place it on a flat surface, such as a table or workbench, for easier access to the wheels.
2. Remove the Wheels: Locate the wheels that need the tube replacement. The Bravo III usually has four wheels, two on each side. Each wheel has a hubcap covering the axle. Use a flathead screwdriver or your fingers to pry off the hubcap from each wheel.
3. Remove the Wheel Tubes: After removing the hubcap, you will see the wheel tube inside. Carefully pull the wheel tube out of the wheel assembly. You may need to twist and wiggle it gently to loosen it. If the tube is damaged or worn, it should come out easily.
4. Insert the New Wheel Tubes: Take the replacement wheel tubes and insert them into the wheel assembly. Make sure they are properly aligned and seated securely.
5. Replace the Hubcaps: Once the new wheel tubes are in place, put the hubcaps back onto the wheels. Press them firmly until they snap into place, ensuring they cover the axle and wheel tube.
6. Repeat for other Wheels: If you need to replace the tubes on multiple wheels, repeat the process for each wheel that requires a replacement.
7. Test the Pool Cleaner: Once all the wheel tubes are replaced and the hubcaps are securely in place, place the Aquabot Bravo III back into the water and test its operation. Ensure that the wheels are turning smoothly and that the pool cleaner is functioning properly.
Note: It's recommended to refer to the specific user manual for your Aquabot Bravo III pool cleaner for detailed instructions and illustrations on how to replace the wheel tubes. The manual will provide you with any additional information or precautions specific to your model.
