20 Most Recent
Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300 Questions & Answers
The rollers will not go up and down anymore;
Your set up is most probably: an electric motor turns a worm gear that turns a large spur gear that turns a smaller spur gear that rides on a rack gear. The smaller spur gear (pinion) that rides the rack (yes, as in rack-n-pinion), allowing the up-and-down travel of the massage balls, has broken teeth which may not be visible because it's hidden under the larger spur gear. They are all plastic gears with lots of white grease.
Massager squeaks
Zip off the cover and add some talcum powder to the inside cover where the roller make contact with the cover.
HOW TO FIX smb400h homedics cushion
Hi
Kindly advise what is wrong with your cushion or kindly advise how your cushion is malfunctioning before i advise you further.We can order the necessary spares &repair.
Where can one get an
Home power adapter for the SBM300 is an ADP 2007. There are a few used ones for sale on line.
