I am having trouble adjusting shoulder straps
Funny, I was just putting this seat back together after taking it apart to wash it. It is a very difficult process, simply because you have to remember which order to loop the buckles through the stap.
First, I assume you want to switch from the lower holes for the shoulder, to the upper. (If not, then there is no adjustment needed. Unless the strap is caught in the back which will make the straps uneven when you go to tighten them. This has happened to me).
So, first you need to remove the straps. Once the seat is removed from the car, look at the back of the seat and you will see a metal bracket that is holding three straps. The bottom strap is not removable from that bracket. The top two strap are attached to the bracket with loops. Remove the straps by sliding them out (edge of the strap has to come out the hole first, then the rest will slide out very easily), Once out, from the front of the seat, pull the strap through the holes
At this point you must decide whether you simply want to adjust the seat, or wash it too. I highly suggest washing it if you haven't done so recently. If you gone this far, go all the way. But since you only asked to adjust it, and the method for removing the cover is much more complicated, we''ll move on to adjusting
Now that you have the straps pulled through, be sure that the straps are not twisted, and simply push them through the desired holes - upper or lower - and reconnect to the loops brace (remember, edge in first).
If you are having problems with the straps not being even when tightened (one side tight on shoulder, other side loose), remove the seat and look to see if the strap is caught on something.
I'm retiring my seat today after six years and two kids. I could use it up to 80lbs, but it makes it difficult to get to the third row of seats in my car. So now we have two no-back boosters.
