20 Most Recent
Eddie Bauer Musical Rocking Bassinet 10330WOW Crib Questions & Answers
Where can i find the bedding for the eddie bauer
Most baby stores (Babies R Us, BuyBuy Baby, Toys R Us, etc) carry bassinet sheets. They have elastic edges so they fit most sizes. I found that for my granddaughters abssinet, there were few color choices so I used pillowcases and tucked the excess under the mattress. Other than that, if you want something made specifically for your brand, generally you'll need to contact the manufacturer or make it yourself.
Cleaning eddie bauer bassinet
First take off the battery cover ( your will need a screw driver). Once you do that take out the batteries and you will see a big screw, unscrew that and take out the screw. You will repeat the same thing on the other side of the bassinet, but you access the screw right on the outside (not like through the battery compartment with the other side). Once both of those screws are removed push back the plastic clip on the inside holder and the bassinet will lift right off. Once the bassinet is off you can take the cover right off. It says to hand wash with cold water and line dry. Hope this helps
I need the bottom skirt and board for the
You can order parts for your Eddie Bauer Bassinet by contacting Dorel Juvenile Group (the parent company of Eddie Bauer baby products)
You can contact them
via email:
[email protected]via fax: 800-207-8121
via phone: 800-544-1108 M-Th 7:00am-6:00pm and F 7:00am-4:00pm EST.
Changing the Canopy
The canopy has two plastic poles for shape that you can remove so you can put the material in the washer.
