20 Most Recent
Pride Rally 3 Wheel Scooter Questions & Answers
Old Pride Rally won't charge or run
The batteries may be too old to take a charge. They are gell cell types and can be had at any battery shop. You can get them on line too, but shipping will be high.
Scooter is old
My advice is to buy a good used one on ebay. There are some real bargains to be had! I really don't regret mine. If you have to travel to get one remember that even the good low cost airlines like Flybe carry scooters free of charge -you just need to ask in advance
How to bypass key switch on pride legend side
While this can be done I do not suggest it. The lock out system is then overridden and the scooter can become dangerous. Also the charger and other electronics will not function correctly. Replacing the switch can be easily done. Parts can be obtained through monsterscooter.com
How do you get to the battery compartment
This should simply be a case of lifting the seat up and off (please be careful, they are quite heavy), then remove the rear plastic cover/shroud that id located directly beneath the seat. There should be two batteries located directly underneath this plastic cover. You may need to hold the seat rotation lever upwards to remove the seat. Hope that has helped.
Pride Zero Turn 10 - 4 beep code randomly while driving.
It is called the "current limit time out." Apparently the battery needs to recuperate or adjust its charge across the cells. That is another question. What it needs is a few minutes to be turned off. I know this from seeing the manual.
https://youtu.be/PB2JsjU9m3A?si=QEXCzBoW3ni5mWyi&t=122
