20 Most Recent
Pride Mobility Products Pride Mobility Victory 3 Wheel Scooter with 35 Ah Battery & Charger + Flat Free Tires Fabric Seat Coverings Questions & Answers
Hi: When I take my thumb off the throttle my
A 13 year old working brake on a scooter is remarkable. This brake part is available and can be purchased for between $60 and $260 retail depending on model and SN. Labor is under 1 hour. You can do it yourself, installing it on the end of the motor.
If you want to clean out the dust of the disc brake you can try a strong spray of air. The dust could cause slippage if the brake were a year or two old.
After 13 years you are ready for a new brake and a new scooter so I am not sure you want to put a lot a money into repairs.
The throttle potentiometer also controls the brake engagement when you release it. You may want to invest in a new throttle pot as well ($80). This item wears out regularly. Hope this helps.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
