20 Most Recent
Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat Questions & Answers
My scooter has started to make a clicking noise
hi , sounds like the brake is clicking which in this case is normal, sometimes as the brake wears the clicking get nosier. Can you please confirm where the clicking is coming from ??.
Regards
Rob
www.gewizrepairs.co.uk
No reverse and lost speed
that could be that you need a new pot for spped control bar, is there any up and down movement ? if yes that could be intermittant
Regards
GeWiz.
Scooter stops after about 3 mile as if battery dead
hi, okay now does this happening every time ? or is the distance variable ?check the batteries are fully charged, if possible check the batteries with a electrical meter when it stops again , insert the probes in the charger socket the outside ones , the middle on you can ignore , check the voltage , below 23 or 24 volts this means that once you start going again the voltage will drop causing the controller to cut out , they normally cut out at about 18 volts .Satisfied that's okay now the brake could be breaking down ? do you hear it click when going along ?At worse your controller could be breaking down Regards
Battery power on mobility scooter
Most scooters show a drop on the battery level meter when in use, as long as it is`nt slowing down it should`nt be a prob. I mean,when you engage the throttle you ARE putting a load on the batteries,so it`s only par for the course that the indicator would drop a bit.
Wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
New battaeries willnot hold charge
Sounds like you have a bad charger. If you have access to a volt meter you can set it to volts DC put the meter to the batteries then plug in the charger. If the volts go up on the meter after you plug in the charger is working ok.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
