20 Most Recent McCulloch 13HP 338 Cc Portable Generator # FG6000MK Questions & Answers
3answers
10 kw deisel generator in sailboat suddenly stopped generating,
Are you still looking for help with your Gen. ? If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
10/11/2017 7:12:12 AM • McCulloch 13HP... • Answered on Oct 11, 2017
3answers
We are a generator repair facility in Shreveport
Hello McCulloch, Try this site, they may be able to assist you in your new parts search or offer a lead for used components. Parts Spares for Generators and Small Engine Machinery
5/4/2017 10:48:17 AM • McCulloch 13HP... • Answered on May 04, 2017
2answers
Spring on recoil starter broke
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
10/24/2014 6:41:36 PM • McCulloch 13HP... • Answered on Oct 24, 2014
Have new motor,how does shaft couple to generator
The shaft to engine has male tapered end and fits very tightly to armature of gen. Remove stator and remove center bolt thru armature. Place a piece of hardwood aganst metal part of armature and rap with hammer (one side then the other). Very carefull not to damage the windings or metal parts of the armature. If it does not come loose in short order apply penetration lubricant and wait for it to soak in. Good luck
7/2/2014 8:29:42 PM • McCulloch 13HP... • Answered on Jul 02, 2014
Shorted out generator??
they do smoke if its petrol lol joke sounds like a short circuit check the connections
3/3/2014 10:40:13 AM • McCulloch 13HP... • Answered on Mar 03, 2014
McCulloch Generator model FG6000mk 11hp run good
I did not understand how you turn on generator, as it is always turned on.
If you use the ON/OFF switch it is stopping the prime mover.
If you reset the AC breaker without load, and it stops - it means that you have short circuit after the breaker. Check the output receptacles.
Try this link:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FG6000MK-7096FG6024-966991401.pdf
3/3/2014 10:38:38 AM • McCulloch 13HP... • Answered on Mar 03, 2014
Gas floods from around bowl when running or even
take it apart
10/23/2013 8:32:29 PM • McCulloch 13HP... • Answered on Oct 23, 2013
2answers
McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
9/14/2013 10:13:03 AM • McCulloch 13HP... • Answered on Sep 14, 2013
3answers
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
5/12/2013 8:52:20 PM • McCulloch 13HP... • Answered on May 12, 2013
2answers
My 5700 watt 11 HP McCullough generator wont
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
4/13/2013 9:47:20 AM • McCulloch 13HP... • Answered on Apr 13, 2013
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
96 questions posted
Top McCulloch Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • McCulloch Electrical Supplies
Most Popular Question
generator repair facility in shreveport
  • Electrical Supplies
