20 Most Recent Sunfire True Sub Signature Subwoofer Questions & Answers
Hi, my sunfire Jr. sub has a distorted sound like
I think it will be most likely a semi-conductor device that is overheating. Probably the main amp device. Subs are basically mono amplifiers.
2/15/2018 7:51:51 PM • Sunfire True Sub... • Answered on Feb 15, 2018
My sub makes a crackling sound when i turn up the
that's just likely a dirty potentiometer. (the circuit under the knob)
1/17/2014 4:28:47 PM • Sunfire True Sub... • Answered on Jan 17, 2014
I have a true subwoofer
ebay has em usually
1/17/2014 4:28:03 PM • Sunfire True Sub... • Answered on Jan 17, 2014
Low volume
check the box for air leaks
1/17/2014 4:27:18 PM • Sunfire True Sub... • Answered on Jan 17, 2014
2answers
My sub woofer humms when idle
The humming could be a couple things.. First try a different outlet in a different room..Make sure the RCA is firmly in place if using LFE and none of the speaker wires strands are touching if using Hi-Lvl input. Also if using Hi-Lvl you might be getting feed back from the Amp.
1/11/2013 5:58:06 AM • Sunfire True Sub... • Answered on Jan 11, 2013
Rattling sound with any significant base output
You either ripped your voice coil, or you have something jumping around inside (Screw, nail, etc.). You can tell of a blown speaker by pressing straight in, and if you hear a rubbing noise, then your speaker has disconnected from your voice coil. Mickey mouse jobs include Krazy Glue, but It's touch and go
11/27/2012 3:58:47 AM • Sunfire True Sub... • Answered on Nov 27, 2012
I keep blowing the external
maybe its an issues closely related to the fuse they are a fail safe so somethings failing and the fuse is your first indication ok just me but its not the fuse causing your problems i would say its a 95% chance its other issues
1/7/2011 3:36:13 PM • Sunfire True Sub... • Answered on Jan 07, 2011
I am the proud owner of a SUNFIRE TRUE SUB
you can go to a hardware store and silicone caulk that is black, make sure it is flexible type. clean surface with rubbing alcohol and a cue tip to prep surface area well, allow alcohol to dry,apply silicone front and back of cone evenly bout 16th inch thick and let dry for full cure time on directions of silicone caulk tube. sub will work awesome. ive done this on many car subs of high amps and never had it fail. hope this helps you alot, i understand how it feels
12/30/2010 5:44:31 AM • Sunfire True Sub... • Answered on Dec 30, 2010
Active driver Has a torn rubber surround. I was
phone an electronics parts provider in your area and ask who re -cones speakers.There are usually a few that do that in all major areas.A shop like that will be able to repair it by putting a new surround on it.
12/30/2010 5:35:07 AM • Sunfire True Sub... • Answered on Dec 30, 2010
I have a low frequency hum that is in my sub
you may have a groung problem in the wireing of your home, buy a 110 ground tester at home depo and check your home wireing
9/28/2010 6:56:29 PM • Sunfire True Sub... • Answered on Sep 28, 2010
Low volume on one of my sunfire true sub mkII. It
Before we get too committed to a direction to go, or embark on unnecessary surgery, can we establish that we KNOW it's the speaker and not the amp or source? Perhaps you could swap it with the other one.
Back to basics: is this a sudden-onset problem or did it always behave like this? Try swapping locations with the other one. Bass response is a lot about location, location, location. Standing waves, self-cancellation, phasing. All players in this game.
2/15/2010 6:42:00 PM • Sunfire True Sub... • Answered on Feb 15, 2010
It seems my Sunfire True Sub sig needs repair, but how to do it?
Capacitors either fail spectacularly or in a very subtle way. Every once in a while, they'll explode, in which case it's very easy to spot the one that needs to be replaced, but generally they fail internally, with no visible problems.
(very old units used a wet electrolyte, and the capacitors simply dried out inside)
If you are able to determine which cap is bad, you will definitely need soldering skills to replace it - no way around that.
Soldering isn't difficult to learn, but I can't help you over the internet. :) If there's a craigslist in your area, you might try posting to the "Wanted" section to see if someone can teach you how.
Best of luck to y
1/13/2010 1:37:46 PM • Sunfire True Sub... • Answered on Jan 13, 2010
Need an organization who can service my Sunfire
big red
if its that old then you should keep it look for spare parts from other subs just make sure it is worth it
10/23/2009 10:25:29 AM • Sunfire True Sub... • Answered on Oct 23, 2009
How a hook up my subwoofer with the pc?
Hello
You need to build or buy a certian cable. The cable goes from RCA to mini jack. You plug the mini jack into your computer and the RCA into the input of the sub. I really hope this can help.
Best regards
9/28/2009 9:42:46 PM • Sunfire True Sub... • Answered on Sep 28, 2009
Has light but no sound
The first thing to always check first is the fuse. This will probably involve some disassembly but it is alwayst the cheapest fix and a constant issue.
5/6/2009 2:45:28 PM • Sunfire True Sub... • Answered on May 06, 2009
Snapping sound
send this baby to the manufacturer, great service at fair prices...they will often repair for free
4/18/2009 3:04:15 AM • Sunfire True Sub... • Answered on Apr 18, 2009
Sunfire True Sub Signature Subwoofer Logo
24 questions posted
Top Sunfire Audio Players & Recorders Experts
 Grubhead
Grubhead
nexrad_chris
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sunfire Audio Players & Recorders
Most Popular Question
keep blowing external
  • Audio Players & Recorders
