20 Most Recent
Hitachi SB10Y 4 X 8 Inch Belt Disc Sander With Dust Collection Questions & Answers
Replace safety key?
I tried Tool Parts Direct, but their exploded view only shows the whole switch, which apparently includes the key. I'm not sure what the Hitachi key looks like, but if it's compatible with the ones Sears uses, I know they used to sell replacement keys in a blister pack (maybe 4 - 6 pcs) I bought a package of them from Sears several years ago.
You can also send a request for help to Hitachi customer support at:
http://www.hitachi.com/GlobalSupport/ContactUs?form_type=global_support
Hi, I have been stumped! I rebuilt a Hitachi
This is the Cars and Trucks section of Fixya. You might get more answers listing in another area of Fixya which more closely matches your device.All things considered, maybe apply air pressure and stick the unit under water in a utility sink or big wash tub. Air leaks would bubble like a hole in a tire tube.
Hitachi nailer doesn't fire, it has no leaks. When trigger is pulled there is no back pressure from trigger
I've had that happen before and what I found was one of the Staples or nails had misfired and wedged before leaving the gun. read the manual on how to get to it for that particular model and also it might be a good idea to adjust your pressure accordingly to keep it from happening again. If the force isn't set proper then a nail could Jam , block the mouth and not allow any other nails to exit. It's very easy to do and not that hard to fix once you've done it at least once. Good luck.
