20 Most Recent Kitchen and Much More Power Juicer Questions & Answers
Need the operating manual for jack lalanne power
Manuals for the Jack LaLanne Power Juicers can be found here:
http://www.powerjuicer.com/power-juicer-manuals.php
You might take time to browse the site, you will find How To videos, Tips and recipes.
4/3/2011 10:57:36 AM • Kitchen and Much... • Answered on Apr 03, 2011
Juicer Jar defective with leakage problem.
Question edited for clarity. Question moved from Computers to Juicers. 3 Duplicates deleted. Refresh the page to see your question. Just contact Amazon and Return it. Log into your Account, click Orders, Find that Item, click Return, it will ask why? Tell them it leaked and set on fire when you used it for the fist time!
Returns and Refunds - Amazon Customer Service
Amazon.ca https://www.amazon.ca > help > customer > display Spotlight · Need to Return Something? · Return items using the Online Returns Centre. · Image linking to self service return video · Returns Items You Ordered.
Return Items You Ordered
Return Items You Ordered · To display your recent orders go to ...
Returns
Returns. If you need to return or replace an item, visit Your ...
Amazon Refund Timelines
We typically process returns within two weeks after the carrier ...
Track Your Return
Track Your Return · Go to Your Orders. · Select View Return ... ..
12/12/2023 4:35:05 AM • Juicers • Answered on Dec 12, 2023
I have a singer juice giant model 774 and I cannot
General instructions: clean the basket-filter-screening of your Singer Juice Giant Model 774: First, unplug the juicer from the power source and disassemble it. Remove the pulp container and the juice jug. Locate the basket-filter-screening and gently twist it counterclockwise to remove it from the juicer. Rinse the basket-filter-screening under running water to remove any pulp or debris. Use a soft-bristled brush to scrub away any remaining residue. Rinse the basket-filter-screening again and dry it with a clean towel. Reassemble the juicer. If you need more detailed instructions, you can refer to the manual for your product
10/31/2023 4:30:58 AM • Juicers • Answered on Oct 31, 2023
Jack LaLanne Juicer. The center screen adaptor doe not loosen and caused motor to lock up.
Questions edited for all the typos and spelling errors.
Contact
Jack LaLanne https://jacklalanne.com > contact Contact. June 8, 2016 admin. Your Name (required). Your Email (required). Subject. Your Message. Sending ... 785 Quintana Rd, Morro Bay, Ca, 93442.
Contact Jack LaLannes Power Juicer Customer Service
Consumer https://jack-lalannes-power-juicer.pissedconsumer.com > ... (973) 575-5400. Sales/ Reservations: (973) 287-5150. Spare Parts Order. Send Message.
Jack Lalanne Power Juicer Customer Service Number
addresscustomerservicecenternumber.com https://addresscustomerservicecenternumber.com > 18... Dec 1, 2016 - The customer service number of Jack Lalanne Power Juicer is : +1 (973) 287-5150. For other related queries, suggestions and feedback, you can ...
10/25/2023 6:11:24 PM • Juicers • Answered on Oct 25, 2023
I have a Magimix 5200 XL Food Processor and the juicer attachment is stuck on the spindle.
Question edited from Australian/NZ 'Megimix', to British 'Magimix', the proper maker name. :>) Plus added '(what it is)'. There is a spring operated probe that goes into the base and is part of the safety interlock. Yours is stuck. Funny, I answered this question yesterday. Remove the lid and spray in some WD40 into the hollow exterior channel part of the bowl. Then operate the spring with a cocktail stick or similar. The spring isn't rising to release the bowl from the base.
4/19/2023 2:19:08 PM • Juicers • Answered on Apr 19, 2023
2answers
Where in the UK can
Your part can be ordered on-line from this website:
https://www.unitycart.com/pjss/parts/parts_classic.asp
11/19/2022 8:25:26 AM • Juicers • Answered on Nov 19, 2022
Omega VSJ843QS Vertical Slow Masticating Juicer. Why is the juice coming out thick with my Omega VSJ843Q?
Question edited for clarity, full 'make model (what it is)'. Question moved from Motorcycles! Juice content of the fruit you are using. Try with Granny Smith apples and make sure they are this season and not last years. Also try the juicer with oranges to prove it is the apples and not the juicer. Also try peeling the apples as a test. The skin can block the strainer. Another trick, run the discarded pulp again. https://www.google.com/search?q=Omega+VSJ843Q ..
11/4/2022 5:06:08 AM • Juicers • Answered on Nov 04, 2022
Need manual for panasonic juice extractor miracle MJ 15
This is a vintage machine and no manual exists. The closest I can find is the MJ-66. There is further confusion because they have a MP3 player with the same model number SJ MJ-15! https://manualzz.com/doc/2127449/panasonic-mj--66pr-juice-extractor https://www.manualslib.com/manual/909071/Panasonic-Sj-Mj15.html https://www.ebay.com/p/1875727370 Close enough? Normally you unlatch the top and lift of the parts inside, macerator and screen, clean inside, wash and replace.
Operating Instructions - Panasonic
https://www.panasonic.hk > usm.ashx > MJ-M176... PDF Operating Instructions. Juicer/Blender (Household Use) ... Please read these instructions carefully and follow safety ... back cover. MJ-M176P / MJ-M171P ...
1/3/2022 11:52:42 PM • Juicers • Answered on Jan 03, 2022
What kind of grease goes into
Edible grease.
12/6/2021 9:59:38 PM • Juicers • Answered on Dec 06, 2021
Binatone je570 juice extractor not ever worked
Check the assembly is correct and if faulty, have it replaced under warranty. If out of warranty ... should have checked it sooner perhaps.
10/20/2021 7:47:37 AM • Juicers • Answered on Oct 20, 2021
My auger keeps clogging when I am juicing. It started doing this recently. What is the problem?
Edited question for clarity, 'ager' to 'auger'. Make and model always helps in such questions, but motor isn't spinning fast enough, or the fruit is past its best. https://www.goodnature.com/blog/centrifugal-vs-masticating-vs-cold-press-juicers/ ..
9/8/2021 3:08:51 PM • Juicers • Answered on Sep 08, 2021
I was juicing some radishes, then apples. Then I was going to juice some carrots but my juice would not turn on. I let it rest for 4 hours but it won't turn on. What could be the problem.
Most likely a thermal fuse, possible the motor on your MYSTERY Juicer. Google make model parts schematic.
5/12/2021 4:30:05 AM • Juicers • Answered on May 12, 2021
Breville Cyclonic Super Wizz FP11, need new
ereplacement.com they have pictures for you enter model number Repair Parts Home Appliance Parts Breville Parts SP0000490 Blade Assembly Complete Blade Assembly Complete Part Number:SP0000490 Availability: Special Order [ more info ] Price: $18.65 Quantity: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Add to Cart
5/12/2021 1:35:21 AM • Juicers • Answered on May 12, 2021
Hi, my Breville Fountain model JE95XL does not
if you can tear apart look inside bottom screws look at motor if brushes did not just smoke and or check if does have power to motor when on be careful ...8-10 times most it died because of too much heat of the fuse link size of a asprin pill when it gets up to , thet call it a thermal fuse one over heated it blows and you throw away i dont i fix.SF139E-142 Degree Thermal Cutoff Fuse 110-250V Instant .look up google to see pic .electronics store sell them or online i would mention radio shack but all on line mow a days ..good luck >^.^<
5/12/2021 1:31:59 AM • Juicers • Answered on May 12, 2021
How do I take out the binatone JE 570 basket for cleaning.
does not look like a phone part to me
4/5/2021 9:14:49 AM • Juicers • Answered on Apr 05, 2021
Westinghouse extractor, model WKJEAJ10. Where can I get an assembly diagram?
Contact Westinghouse directly with your request. Follow the diagram in reverse to get access to the motor.
3/23/2021 9:14:30 PM • Juicers • Answered on Mar 23, 2021
How to clean the MaGIC LINE extractor MJE000
google
10/20/2020 11:34:49 AM • Juicers • Answered on Oct 20, 2020
I must be really blonde but I can't figure out how to turn on my zip343 juicer help!
There should be an on button on your blender
7/24/2020 12:02:47 PM • Juicers • Answered on Jul 24, 2020
I am looking for e celery juicer
I think Cuisinart has a pretty affordable juicing line.
4/22/2020 6:03:05 PM • Juicers • Answered on Apr 22, 2020
Kitchen and Much More Power Juicer Logo
1 questions posted
Top Kitchen and Much More Juicers Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Kitchen and Much More Juicer Expert? Answer questions, earn points and help others
View Most Popular
  • Kitchen and Much More Juicers
Most Popular Question
need operating manual jack lalanne power
  • Juicers
