20 Most Recent Dell Precision T3400 375W 32bit Computer Workstation PC Desktop Questions & Answers
a lot of info for what sounded like a simple question. i first thought that maybe you did not have the CD wiring connected properly? if the pc powers on, then that would be my first guess, check the wires you hooked up to the cd player. then 'if ' you have problems with the install of the OS, can the cd player read DVDs? software can be on dvd not cd so the cd player would not work. if you can get into dos, or select PF2 or PF12 on boot to see where your cd is in the boot sequence or even listed. more detail on what you have tried is required when trying to solve an issue. Many of you do not give enough info on what has already transpired in trying a solution yourself. good luck
Dell Precision... | Answered on Jun 24, 2014
Bios, Turn it off or on there.
Dell Precision... | Answered on Jun 03, 2014
PCI card needs power.
Dell Precision... | Answered on May 03, 2014
Reinstall the Window 7
Dell Precision... | Answered on Oct 05, 2013
Few things to check first:
1. Does yr Optical drive support writing?2. Make sure that you have a DVD writing software.
YOu may download the an free CD burning software from here
http://www.filehippo.com/download_nero_lite/
http://www.filehippo.com/download_nero_burning_rom/
Dell Precision... | Answered on Dec 25, 2012
The memory specification for your workstation is here:
http://www.crucial.com/store/listparts.aspx?model=Precision%20Workstation%20T3400
You can remove the 1GB modules and replace with 2*2GB modules to give 4GB and you are correct in that you will need to use a 64-bit operating system to fully utilise 4GB or more.
Hope this helps,
Please rate my answer,
Chris
Dell Precision... | Answered on Mar 09, 2011
try to click this link to download the latest version of Adobe flash player. > http://get.adobe.com/flashplayer/
Dell Precision... | Answered on Sep 24, 2010
It is bios password for that you have to reset *********** bord bios to defaults.
open cpu cabinet and then find CMOS cell on motherbord.
It is like round battery cell.
Then pull it for 10 minutes from motherbord then again refix it in it's position then it not ask for password.
Let me know if you need more assistanse.
Thanks.
Dell Precision... | Answered on Apr 26, 2010
Service Tag (bar code on the back or bottom of the computer):
On more recent model the service tag is on the top and could be without barcode.
Dell Precision... | Answered on Dec 11, 2009
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program
Click Start, click My Computer, and then see whether the drive is listed.
Is the drive listed? loadTOCNode(2, 'moreinformation');
If the drive is listed, try to play or access a CD or DVD.
If you can play or access a CD or DVD, you are finished with this article.
If you cannot play or access a CD or DVD, you may have to reinstall some programs. Some programs might not be able to use your CD or DVD drive until you reinstall those programs. If the problem occurs again when you install or uninstall those programs, contact the manufacturer of the program to see if an update is available that solves the problem. Some examples of programs that might be affected are:
  • iTunes software by Apple
  • Nero software by Nero Inc
  • Roxio Creator software by Sonic Solutions
  • Zune software by Microsoft
After reinstalling your programs, if you can play or access a CD or DVD, you are finished with this article.
If you still cannot play or access a CD or DVD,
If the drive is not listed, remove and reinstall the existing drivers.
Dell Precision... | Answered on Nov 13, 2009
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Dell Precision... | Answered on Sep 19, 2009
Could be a faulty psu or disk drive - suggest test both
Dell Precision... | Answered on Mar 04, 2018
If not data on the flash drive I suggest try reformatting the drive to remove any malware
Many Dell can be a bit funny about exactly what RAM they will accept == check what other owners say on the Dell website user forums ..
Dell Precision... | Answered on Mar 30, 2016
At power-on, use F12 (or F8) and select 'Repair' ... DO NOT let it 'reformat' your drive or you will loose everything ..
If that fails, you may have to choose 'Factory Restore', but this will re-install Windows and you will LOOSE EVERYTHING !!
SO == if you have another PC, I suggest move your disk drive to that other PC and copy off all your photos/music/videoa etc you don't want to loose before doinbg a Factory Restore ..
It's simple. If you still have a problem please take a look at manual in pdf file for this dell t3500. You can find it here for example:
User manual for Dell T3500
Dell Precision... | Answered on Sep 19, 2015
Windows 10 is new and still in testing phase, new patches are released to fix bugs almost everyday. try running an update, make sure your hardware was compatible and the OS is installed properly, you do have the option to roll back if you want to.
call 1-877-805-1027 for expert help.
Dell Precision... | Answered on Aug 21, 2015
PCProtect is malware. What is PCProtect exe . I would boot up in Safe Mode again, or Normal if you have to, and bring up Task Manager again (Ctrl-Alt-Del) and check to see if explorer.exe is running. If not, Click on File in the Task Manager toolbar, select New Task (Run), and type explorer.exe in the Open box and click OK. If all goes well, your icons and Start Menu will appear and you can start cleaning up. Otherwise, you could try again and type appwiz.cpl in the Open box to bring up the Programs and Features to remove any bad programs you may find. Malware removal can takes years of experience, so I will leave it at that to try for a starting point.
Dell Precision... | Answered on Jul 31, 2015
Dell Precision T3400 375W 32bit Computer Workstation  PC Desktop Logo
16 questions posted
Clive
Clive
Alun Cox
View Most Popular
Precision Dell
  • Precision Dell
Most Popular Question
dell diagrams
  • Computers & Internet
