20 Most Recent Macally G-S350SUA 3.5" Hard Drive Enclosure Serial ATA, FireWire , USB 2.0, eSATA Drive Case Questions & Answers
Macally G-S350SUA power supply
  • I have the same Macally hard drive enclosure and I misplaced my power supply also. I used an old IBM Thinkpad power supply. These are common and cheap. The Macally enclosure states 12V DC input, and the Thinkpad PS is rated at 16V but it works fine. The plug and polarity are correct.
7/7/2014 2:43:51 AM • Macally... • Answered on Jul 07, 2014
0answers
0answers
It wont turn on and my computer will not acknowledge it.
Generally,
This is either an AC adapter problem or a failed circuit board in the Caddy. Unplug it completely for about ten minutes, then reconnect the cords. It may fire back up, if it doesn't you will need to test the drive in another caddy, pop into your local computer store and grab one, or have their techs swap it for you and test it,
If neither of these works then the HDD itself may be dead inside the caddy, let me know and I can point you to an appropriate pro to get the data recovered.
Chris
5/26/2009 7:32:16 PM • Macally... • Answered on May 26, 2009
How to turn off macally scroll lock
Click on the Apple menu in the top left corner of the screen.
Select "System Preferences" from the dropdown menu.
Click on the "Mouse" or "Trackpad" icon in the preferences, depending on the Macally device you are using.
In the "Scroll & Zoom" tab, look for the "Scroll Lock" option and uncheck it.
This should disable scroll lock on your Macally device. If the "Scroll Lock" option is not available in the system preferences, you may need to install the latest drivers for your Macally device."
2/17/2023 11:59:21 PM • Macally... • Answered on Feb 17, 2023
How do I turn off scroll lock on a macally keyboard
You should be able to do that by pressing the "Fn + Scroll Lock (F14)" keys simultaneously.
2/17/2023 8:50:45 PM • Macally... • Answered on Feb 17, 2023
My macally keyboard doesn't stay on even when fully charged
There are a few potential reasons why your Macally keyboard is not staying on even when fully charged:
  1. Battery issues: The battery in the keyboard may be faulty or malfunctioning. It's possible that the battery is not holding a charge or is not working properly.
  2. Power management settings: Check your keyboard's power management settings and make sure that it is set to stay on when fully charged. Some keyboards have a sleep mode that turns off the keyboard when not in use to conserve power.
  3. Connectivity issues: Make sure that the keyboard is properly connected to your computer. Also check if the keyboard works with other devices.
  4. Firmware update: Make sure you have the latest firmware update for your keyboard. Sometimes an update can fix any bugs that cause the keyboard to turn off when it's fully charged.
  5. Damaged charging port: The charging port of the keyboard may be damaged and not able to charge the battery.
It's recommended to contact the manufacturer's customer support team, they will be able to assist you in diagnosing the problem and provide a solution. If the keyboard is still under warranty, you may be able to get it repaired or replaced for free.
1/16/2023 11:55:24 PM • Macally... • Answered on Jan 16, 2023
Can I leave my Macally rechargeable bluetooth keyboard n all the time? Even when computer is off. What is expected battery life?
the manual should cover that. but varies, on actual use. the keyboard goes to sleep. the longer is sleeps the longer the battery last. why not just let it do its thing until it dies or makes chararcters like this ou[aopiup0[ep[ ibp[em iepoifpeo[p[eifkp no model keyboard told so can not RTM to you.
1/6/2022 3:01:38 PM • Macally... • Answered on Jan 06, 2022
How do I turn of the short cut and switch to standard F function on the Macally usb Mac Keyboard
If you prefer the top row of keys to always behave as standard function keys without holding the Fn key:
  1. Choose System Preferences from the Apple menu.
  2. Click Keyboard.
  3. Click the Keyboard tab if it's not already highlighted.
  4. Select "Use all F1, F2, etc. keys as standard function keys"
10/11/2017 6:47:12 PM • Macally... • Answered on Oct 11, 2017
Connecting a USB keyboard to my iMac
Adding the keyboard is one thing but without the correct driver, your pc will not be able to recognise it or make it usable. Check in your device list to see if it shows up and whether it is functioning. If not, you need to download the correct driver from the keyboard manufacturer.
9/19/2017 3:57:49 AM • Macally... • Answered on Sep 19, 2017
My Macally mouse just stopped working with my Macbook Pro. the light on the underside of the mouse is out. I purchased the mouse in October 2016.
It sounds as if it is dead and you may have to purchase another, (obviously check batteries connections first) find out if there is still warranty left as i'm not sure if it will be classed as a consumable.
8/6/2017 8:16:24 PM • Macally... • Answered on Aug 06, 2017
0answers
0answers
0answers
Use of end key
Be the first to answer 3/13/2014 4:44:51 AM • Macally... • Posted on Mar 13, 2014Be the first to answer
Macally G-S350SUA 3.5" Hard Drive Enclosure Serial ATA, FireWire , USB 2.0, eSATA Drive Case Logo
Popular Tags
8 questions posted
Top Macally Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Macally Computers & Internet
Most Popular Question
macally g s350sua power supply
  • Computers & Internet
