20 Most Recent Jabra BT2020 Bluetooth Headset Questions & Answers
possibly batts need changing/replaced. they do wear out
Jabra BT2020... | Answered on Jun 29, 2014
this might be the issue you are having
Cons: BT is supposed to work at 30'. Could never get more than 10' away from a phone. Worse, their batteries short out & will not hold a charge and the unit will not turn on after 6-8 months, max. I know as I have had 6-7 units all with the same result.
here is the link
http://reviews.cnet.com/headsets/jabra-bt2020/1707-13831_7-32742719.html
Jabra BT2020... | Answered on Sep 24, 2010
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
password is 0000
Jabra BT2020... | Answered on Aug 07, 2010
Jabra BT2020... | Answered on Jul 30, 2010
Hi terry, first thing to do is,
  • make sure the headset is off.
  • press and hold the answer/end button until a solid blue light comes on.
  • go to your phones settings turn on the bluetooth.
  • select the option on your phone to discover or add a bluetooth device.
  • your phone should discover the jabra bt350.
  • your phone will then ask you if you want to pair with this device.
  • accept by pressing ok or yes.
  • confirm with the pass key or pin = 0000
Jabra BT2020... | Answered on Mar 23, 2009
If you are talking about the code needed to pair it up, it should be 0000. It is in the user manual.
Jabra BT2020... | Answered on Jan 04, 2009
I don't know how long you have had the headset but it sounds like it isn't holding a charge.  Contact Jabra to find out what the warranty is on the headset.
Jabra BT2020... | Answered on Nov 12, 2008
If your phone is connected via Bluetooth to the Jabra, I cant see why not. It would be a case of try and see otherwise contact the suppliers and ask them.
Jabra Radio... | Answered Yesterday
Mute/Unmute: Tap both the Volume up or
Volume down button at the
same time
Jabra Radio... | Answered on Apr 03, 2019
you can buy new ones for very cheap don't be so darn cheap
Jabra Radio... | Answered on Mar 20, 2019
Jabra BT2020 Bluetooth Headset Logo
19 questions posted
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Radio Communications
Most Popular Question
install jabara bt530 phone
  • Radio Communications
