20 Most Recent
Samsung HT-X250T Theater System Questions & Answers
My samsung home cinema system - HT-X250; Trips off
Had this same issue with my Samsung HT-X50, it seems these systems have cheap fans. Mine was under warranty but when I contacted samsung they wanted me to pay to ship it to them. **** that, it would of cost me 70 to ship.
What I did was open the unit take the fan and go to a computer store asking for a similar one, I got all this done for about 10 bucks. **** that samsung warranty
Hi, after aprx 1.5hrs of
Sounds like you have a cold solder connection somewhere on the main board or power supply. It opens when the junction begins to heat up after prolong use. It probably corrects itself when the unit is cold and the junction re-connects. Your best remedy is to inspect the boards and try to locate the bad solder connection. You can do this, but please be careful when working on live circuits, by using a non-conductive pointed tool and poke at suspected joints on the circuit board - if the unit begins to work again, Bingo, you found the problem.
Good-luck!
HT-X250 Trips off then says "Protection"
I'm afraid that's teh case with your unit. PROTECTION error actually means the unit is overheating and it shuts itself off to avoid further damage. Just make sure that there are no other device below the unit and that there is adequate ventilation at the back.
If all else fails, the unit's fan is definitely defective.
Region Error
please try if this helps:
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
