20 Most Recent Samsung SyncMaster T200 LCD Monitor Questions & Answers
Greetings fellas !!! I got
Is it (mechanically) stuck?
12/19/2017 2:35:58 AM • Samsung... • Answered on Dec 19, 2017
Hi, I want to connect a new xbox 360 to my Samsung T200 lcd monitor. there is a VGI socket and a DVI socket in the back of the monitor. The VGA socket is already connected to my PC and I would like
You can only use one device at a time with the monitor. Also the monitor doesn't have speakers, so you will not get any sound. There is another device which you can use to connect both your computer and your xbox to the same monitor. It is called a KVM switch. You can buy it from a local store or online.
9/13/2017 2:18:41 PM • Samsung... • Answered on Sep 13, 2017
I want to ask how to open case on SyncMaster
Its sitting around snapped first remove the hoof and look for some screws to find open with a putty knife or very flat tool, but beware the cap has tabs that must be slowly loosened otherwise they will break.
3/4/2016 2:34:32 PM • Samsung... • Answered on Mar 04, 2016
Settings for reading
HI USR THIS LINK http://www.cnet.com/products/samsung-syncmaster-t200-lcd-monitor-20/specs/
2/23/2015 11:06:01 AM • Samsung... • Answered on Feb 23, 2015
0answers
Sync master t220
Be the first to answer 10/4/2013 11:53:14 PM • Samsung... • Posted on Oct 04, 2013Be the first to answer
Right side, settings buttons !
your side button are get dusted and short may b so open this Cover of LCD and replace those buttons.
9/14/2012 10:23:09 AM • Samsung... • Answered on Sep 14, 2012
Problem with Samsung SyncMaster T200: After
try with new vga cable
3/19/2012 8:37:30 PM • Samsung... • Answered on Mar 19, 2012
Hello. I have a samsung
Either your PC video card has fried or it is in fact the monitor that is malfunctioning. Try plugging another monitor into the PC to test which is the problem. If the test monitor still doesn't display your desktop then it is indeed a problem with your system and not the monitor. In this case you will need to have a techinition assess the damaged components. If you can faintly see your desktop in the background then it may be a backlighting issue with your monitor. See my tip here: http://www.fixya.com/support/r6836567-lcd_monitor_displays_background_fine
4/17/2011 10:05:26 PM • Samsung... • Answered on Apr 17, 2011
I have a T200 syncmaster
It is telling you that it is not getting the video signals from your PC, you should try another monitor with this PC or try this monitor with another PC to narrow down the cause of the problem.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
3/25/2011 6:32:16 PM • Samsung... • Answered on Mar 25, 2011
2answers
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
8/19/2010 12:49:45 PM • Samsung... • Answered on Aug 19, 2010
I have the proper driver installed but the monitor
Connect the monitor to a different desktop/laptop, to prove that it is capable of working, at least some of the time.
Connect a different monitor to your desktop computer, to prove that your computer's video-card is working.
8/19/2010 4:06:41 AM • Samsung... • Answered on Aug 19, 2010
My monitor is hooked up properly but for some
The function keys across the top when the computer is "firing up" will trip the very base level of the computer operating system. Suspect the correct driver is missing, thus if you can reset it here, you will be able to see enough to get on the web. On the web search for drivers, or go straight to Samsung and download and install the proper driver, than reboot.
8/19/2010 3:08:05 AM • Samsung... • Answered on Aug 19, 2010
Monitor has lost power, cant seem to fix, have
i think your monitor seems unable to repair yourself if it is under warrenty you can repair it for free else the samsung company will provide you a new one . otherwise if it can be repaired i think it will be little costiler. better contact your nearest sasung servive center hope they will properly guide you
6/9/2010 2:21:34 PM • Samsung... • Answered on Jun 09, 2010
2answers
The monintor will not display
Check the pwer supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
6/1/2010 8:19:29 PM • Samsung... • Answered on Jun 01, 2010
Samsung SyncMaster T200 LCD Monitor Logo
45 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
right side settings buttons
  • Computers & Internet
