20 Most Recent LG GSA-H55N DVD-RAM Burner Questions & Answers
2answers
I have an LG DVD writer, Model GSA-H55N, that I
What are regional codes ?
Motion picture studios want to control the home release of movies in different countries because theater releases aren't simultaneous (a movie may come out on video in the U.S. when it's just hitting screens in Europe). Also, studios sell distribution rights to different foreign distributors and would like to guarantee an exclusive market. Therefore they required that the DVD standard include codes to prevent playback of certain discs in certain geographical regions. Each player is given a code for the region in which it's sold. The player will refuse to play discs that are not coded for its region. This means that a disc bought in one country may not play on a player bought in another country. Some people believe that region codes are an illegal restraint of trade, but no legal cases have established this.
The world is split up into 8 DVD regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Old DVD-ROM drives came with a firmware level RPC-1. Software protection was used to control which region is played.
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
How to bypass DVD region code protection ?
As we've said, a lot of newer drives are RPC-2 drives these days. Some of these drives don't allow raw access to the drive until the drive firmware has done a regioncheck. But some RPC-2 drives DO allow raw access, so in some cases it is quite possible to use a special software to bypass the protection:
The first solution is free VideoLAN player: click here to download VideoLAN. It might take a long time to initialize DVD. So just pop the disc in your drive and try it out, while you get a coffee.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition as shown below:
Click Start Player button, and try to play your DVD.
How to change DVD region ?
The region can only be changed five times, before its set permanently.
In WinDVD: if a DVD from a region different than the default one is tried to be played, the dialog box for changing the DVD region code should appear. If that dialog box do not appear, check the region code set in the software:
Click Start, All Programs, Intervideo Win DVD, and Intervideo Win DVD.
Right-click the Win DVD window and select Setup or Properties.
Click the Region tab and check the region code selected.
If there is a 0 in the Changes Until Permanent field, the DVD region code will not be able to be changed again.
If a number from 1 to 4 appears in the Changes Until Permanent field, add a mark in the checkbox of the desired region and click OK. The new region will be set up.
In PowerDVD: the first time you insert a DVD title, to be played on PowerDVD, a small dialogue box will appear. It will set the region code to match that of the DVD title you wish to play. After this the program will be set. However, if you have a region free DVD-ROM drive, you have the option of playing DVD titles from different regions. PowerDVD will allow you to change the region code setting up to five times, and then it will be locked on the region you have listed on your fifth and last change. At that point you will only be allowed to watch DVD titles from that region. To change the region code, from the original setting, just insert the DVD title in your DVD-ROM drive and run PowerDVD. When the software recognizes that the disc is from a different region than what was previously set, a dialogue box will appear. For this example, the Current Region is Region 1. After changing from one region to another, I will have four changes left. The program detected the disc I inserted was from Region 2, so it selected this option. Once I click OK the Current Region will be changed to Region 2 and the DVD title will play.
How to make DVD-ROM region free ?
If your drive is locked, DVD doesn't play and you can't change region code or bypass protection using described methods, then the last & only working solution is to "patch" your DVD-ROM drive, and replace hardware region code protection mechanism. It's a dangerous method, which can be used only by PC professionals.
If you live in the USA or Canada (R1) then you most likely won't need the ability to play DVDs from other regions, unless you are interested in some of the rare titles that are out in Europe (R2) but not in the USA. If you live in Europe and you prefer to watch the movies in English then most likely you have to flash your firmware (in order to buy American DVDs).
Load another firmware which disables the region code protection. This is ONLY for advanced users!
Step 1. If you're unsure about the type of the drive I suggest you run driveinfo.
Download DriveInfo program from this page: http://www.remoteselector.com/driveinfo.htm
In case of ASPI error you have to install forceaspi first. Here's download link with instructions on how to install it: http://force_aspi_18.w.interia.pl/. After installing forceaspi you have to reboot your machine. Driveinfo will show you the type of your DVD drive as well as the current firmware, and whether or not the drive is regionfree. If driveinfo tells you the drive has no region protection of course you don't have to do anything.
Step 2. After you determine the type of your firmware you should download _EXACT_ version of patched firmware. Go here: http://forum.rpc1.org/dl_all.php and check if there's an updated firmware for your type of DVD drive. This step is really crucial! Double or triple check that you have the right firmware, otherwise your drive might not work after flashing anymore (and unfortunately there are flash programs that allow you to load the wrong firmware). Bad flashing could destroy your drive definitively. Read carefully the installation notes of your firmware before you upgrade. The Firmware Page and the drive manufacturer can't be responsible. AND REMEMBER: This is at your own risk.
Step 3. After you've downloaded the right firmware you'll have to create a Windows bootdisk. You can format a disk and check "copy system files" and you'll get a working bootdisk. Then copy the flasher program and the firmware to the disc as well. Then reboot your pc and change the boot drive order if necessary so that your pc boots from the disk drive. Since every BIOS looks different I can't tell you where to change the boot order. Please refer to the manual of your mainboard / pc or call customer support.
Step 4. After rebooting run the flasher. Then the program will search for a DVD-ROM and ask you if you want to flash. Type yes, wait until the program has finished, then reboot your pc. Once back in Windows run driveinfo again. If everything has gone as it's supposed to that's what you're supposed to get. Enjoy.. you've just beaten the DVD-ROM Hardware region-protection system.
12/27/2023 11:55:16 AM • LG GSA-H55N... • Answered on Dec 27, 2023
3answers
LG DVD gsa-h55 driver .inf file
I doubt that you'll be able to getmuch support for a product that hasn't been released to the puiblic yet.
The edition you have will be a Release Candidate which was released to developers to find any bugs.The RTM has only just been released to manufatures so that they can develop the drivers for when it goes on general release.
Basically you're jumping the gun a bit.
5/6/2022 9:11:23 PM • LG GSA-H55N... • Answered on May 06, 2022
0answers
2answers
My lg dvd rom is not reading dvds
Try deleting upper and lower filters of your optical drive. To do that, run regedit on start search. Then, follow this path: local machine, system, current control set, control, class, 4D36E965- E325 - 11CE - BFC1- 08002BE10318. then on the window under Name, look for upper and/or lower filters. right click on it and delete. restart pc. then you're good to go.
11/21/2013 6:22:25 PM • LG GSA-H55N... • Answered on Nov 21, 2013
Burner doesn't burn correctly (error 000007). Is
Well I would recommend cleaning the dive, making sure you are using the proper media, make sure you are using good software and that your disks aren't already bad before starting. If you need further help, I’m available over the phone at https://www.6ya.com/expert/chad_70dccdc9090b1a75
9/18/2013 10:06:33 PM • LG GSA-H55N... • Answered on Sep 18, 2013
I cant read any dvd
My DVD drives would not read DVD's. I downloaded Microsoft Fix It Center software and fixed Windows media player. I had corrupt files that would not let my drives read DVD's. After the corrupt files were fixed my drives work just fine.
12/14/2011 11:18:17 PM • LG GSA-H55N... • Answered on Dec 14, 2011
3answers
My dvd drive play cd but it cannot show or play dvd
Does the DVD work in other DVD drives?
12/14/2011 11:15:14 PM • LG GSA-H55N... • Answered on Dec 14, 2011
Hi, i am using LG dvd
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area If this does not fix the problem you might try you might have to physically unplug the leads for this cd-rom restart your computer then plug them back in this should activate the found new hardware wizard hope this helps you
9/10/2011 6:09:34 AM • LG GSA-H55N... • Answered on Sep 10, 2011
It is asking for CD-R/Rw
thought i just answered this anyway
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps you
8/24/2011 5:10:44 PM • LG GSA-H55N... • Answered on Aug 24, 2011
My lg super multi DVD
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
8/19/2011 8:30:57 PM • LG GSA-H55N... • Answered on Aug 19, 2011
Driver cd dvd
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps
8/9/2011 9:04:35 PM • LG GSA-H55N... • Answered on Aug 09, 2011
My lg dvd writer cannot
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
6/7/2011 10:02:37 PM • LG GSA-H55N... • Answered on Jun 07, 2011
My burner plays and reads
Hi bcwailing ,
The problem that you have described, indicates that your DVD-RAM is not working properly, perhaps the lens has been damaged or the software that you are using for burning the cd is not functioning properly due to change in settings, I would recommend you to do the following steps and check if it works :-
  1. Make sure that the software that you are using to burn the CD , is working properly ,a good idea would be to uninstall and reinstall the software , I believe this should help you out.
  2. If the above trick does not work ,then you can use your inbuilt windows cd writer to test write a cd , by right clicking the files you want to burn and select the send to option and then select the write these files to cd or selected the rewritable disc option.
  3. If the above method does not work , then you need to get a replacement for your DVD-RAM drive , in case it's under warranty , or you need to buy a new one , if it's damaged out of warranty, there are people who try to ask a third party vendo to chage lens , but it's not assured and could waste your valuable time and money.
Hope this helps...:)
5/12/2011 3:46:27 PM • LG GSA-H55N... • Answered on May 12, 2011
0answers
LG GSA-H55N DVD-RAM Burner Logo
132 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GSA LG
  • GSA LG
Most Popular Question
lg dvd writer problem not reading cd or
  • Computers & Internet
