20 Most Recent
Rainbow Six Vegas - PC Games Questions & Answers
Rainbow six vegas 2 running
i had the same problem. First, try downloading any patches that maybe be new, they can help.
then once in the game menu, go to the options and decrease the visual effects and graphics. they made this 2nd game to run in defalt mode with HIGH graphic computers, but if you just lower things to 800x600 and then set things to low, the gaame should run better, wont be perfect, but you will be able to play it with out getting mad at it..lol
D3d9 download swiftshader
This is probably because the graphics card you used, did not meet the minumum requirements which are 128MB, Shader Model 3 and DirectX 9.0c compatible
SwiftShader is now open sourced software that enables 3D rendering on systems that can't fully support hardware-accelerated rendering. http://blog.chromium.org/2016/06/universal-rendering-with-swiftshader.html
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
