20 Most Recent
Kaspersky Labs Internet Security 7 Full Version for PC Questions & Answers
Kaspersky internet security 2010 and firewall issues
Your antivirus program is probably thinks that your Wireless Network monitoring program is not a possible malicious program. there should be an option somewhere to set which programs are ok and which are not.
Kaspersky is blocking my wireless internet
in the kaspersky you can see turn off firewall and try to access the wireless connection and you need to update the programs rules thats why its blocking the internet.
When I boot the computer
What it says is that there might be software which acts as a keylogger installed on your computer. Very briefly, keylogger is software which records everything you type on your computer. However, kaspersky sometimes happens to give a false positive and recognize software as keyloggers , whereas they are not. So, try to see where this software is located and check if it really contains a keylogger!
Make computer run faster
You can speed up your PC with the help of these tips given below:-
1) Defragment & Optimize files in the hard disk regularly.
2) Disable the unwanted start up programs.
3) Defragment the registry if needed.
4) Uninstall unnecessary programs (Games, crapware, toolbars, etc.)
5) Install latest Windows updates.
For task 1, 2 and 3 use reliable program like I always use "RegInOut" for the best performance. Remember that Windows need above to be optimized from time to time. So regular maintenance is required.
My activation code for my kaspersky antivirus wont
I need to know your Kaspersky version to help you with the activation code. In the meantime, search Google using this text: ("kaspersky 2013", torrent) without brackets and select any link with a keygen or serial /code. Then download it with uTorrent and install it.
Losing internet connection
First of all I would suggest you that contact with your ISP ( Internet Service Provider ) If they say: everything is fine! then perform these tips to fix your issue:-- Update device drivers.- Check your Preferred DNS address.- Disable Firewall.- If you have Free-trial antivirus then uninstall it.- Uninstall p2p software's (uTorrent, BiTorrent, Team Viewer.)- Optimize internet setting's (must use reliable program PC Fresher for best result.)- Install latest Windows updates.- Restart PC
