20 Most Recent GE AHK40LK Dehumidifier Questions & Answers
0answers
0answers
0answers
My basement had a lot
It may be gathering water, but the tubing to the drain bucket may be clogged. Turn the unit off, unplug it and remove the drain bucket. With a flashlight, look up into the interior of the cabinet and you will see a small tube or water outlet. Using a flexible Zip Tie (at least 6' long), carefully insert it into the drain tubing or hole. And carefully move it back and forth. This should remove any clogs.
Also, check the filter on the unit, as it to may need cleaning, too.
If you've had this unit for a number of years and the above trouble shooting doesn't solve the problem, it may be time to replace the unit.
Also, if you continually have "a lot of water" in your basement, you might want to install a sump pump. In the long run, it's a better solution and will pay for itself in a couple of years.
3/2/2011 3:47:11 PM • GE AHK40LK... • Answered on Mar 02, 2011
0answers
Ice accumulates in the rear of the dehumidifier.
The one that is iced up probably developed a freon leak and yes it will cosy more to fix it then to repair it...
This tip will give you some things you can check first...
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
5/18/2010 10:56:46 PM • GE AHK40LK... • Answered on May 18, 2010
Fan runs, seems to work ok... but not pulling water out of the ai
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
5/5/2010 3:31:42 AM • GE AHK40LK... • Answered on May 05, 2010
How do I clean the filter on a GE Sahara 25 dehumidifier?
First remove the bucket. Easily clean the filter w/warm soapy water either under lightly running water or carefully gently clean w/towel. Tap lightly to remove any excess water. Place filter up to air dry which shouldn't take long. After putting filter back in, press. & hold the clean filter reminder button for at least 3 seconds.
9/2/2020 5:23:50 AM • GE Dehumidifiers • Answered on Sep 02, 2020
Does my GE model # APEL70LT1 Dehumidifier have a recall . Purchased in 2016
You must contact GE on this question.
5/1/2017 10:06:42 PM • GE Dehumidifiers • Answered on May 01, 2017
GE AHK40LK Dehumidifier Logo
17 questions posted
Top GE Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
GE Dehumidifiers
  • GE Dehumidifiers
Most Popular Question
fan runs seems work ok but not
  • Dehumidifiers
