20 Most Recent
Destroyit 5009 Shredder Questions & Answers
Destroyit 5009 Shredder No power to the oil pump.
Investigate the operation purpose of the Oil Pump. Did you measure the voltage across the terminal or observe that the pump was not operational. It must have an auxiliary function that is not related to main operations. Investigate the purpose of the Oil Pump and deduce what would make it operate then check that switch if their is no voltage measured across the pumps terminal when it should be operating. This deductions may help lead to the problem and a solution.
This destroy it model 3801
Hello and welcome to Fixya.com
the most likely cause of this is that paper is jamming the shredder drums and the paper sensor in shredder is blocked by u guessed it paper, try spraying WD40 into the machine and then running it backwards and forwards to unjam it, if it will not unjam then u have a failed motor or jammed/damaged shredder drum, in that case the best thing to do is just replace the shredder .
