20 Most Recent
Destroyit 4107 Shredder Questions & Answers
Destroyit 4107 keeps clogging
There could be several issues that can lead to this.1.) check voltage, has anything been added to the circuit that could be reducing the voltage/amperage to this shredder2.)excessive debris stuck around the cutter shafts 3.) is oil getting to the cutter shafts4.) remove side panels and check the make sure the drive chain is lubricated.Might not solve it but it's a good place to start.
This destroy it model 3801
Hello and welcome to Fixya.com
the most likely cause of this is that paper is jamming the shredder drums and the paper sensor in shredder is blocked by u guessed it paper, try spraying WD40 into the machine and then running it backwards and forwards to unjam it, if it will not unjam then u have a failed motor or jammed/damaged shredder drum, in that case the best thing to do is just replace the shredder .
