20 Most Recent
Alpine SPS-600C Car Component System Questions & Answers
I have alpine sps600c &
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
Wiring Apine SPS-600C speakers
hey there,i hope the project turns out great,
1) round up all materials needed such as door components and indash radio,install plug for aftermarket radio,get a radio install kit they are like 10-15 bucks ,and if ur doing a double din radio you will have to cut trim to fit and inside compartment behind radio,but if your doin stock 1 din you will be fine.
2) in order to get to radio in dash you must pull dash bezel off from around gauges and radio and the radio has push down release tabs on both sides of radio ...push these down and pull radio outwards.
3) use new wire plug harness and install radio using install kit so radio sits in it and slides back in with tabs.
4) door panels come off with (3)crews that are 7mm near door handle,bottom of door near speaker,and inside where the switch panel is.must pull up switch panel to get to screw others are visible.
5) take mirror cap off and lift upwards on panel the whole panel will come off make sure to unplug vanity light at bottom door and all switches.remove n set to side door ....remove speaker and unplug then install new speaker cut plug install new crimped wire connector caps and install speaker and do reverse to put door back on and this go's for the otherside as well.
6) if theres more to your system write back with any ?'s ok ill try to help as much as possible.
couldn't find anything about the network?
Im having trouble installing the sps-600c alpine
Hello lucal_s2000,
Well, actually those 600c's do have a crossover. It's encapsulated in the wiring you got with the components. Your head unit or amp speaker outputs connect directly to the woofers. The inline crossovers have a 12" wire on one end and a 22" wire on the other end. Connect the 22" side to the 2nd set of terminals on the woofers, and the 12" side to your tweeters, keeping all of the positives and negatives straight.
Here's an image of the connections.
Hope this helps.
Installing apline sps- 600c
use only one set of factory wires into the crossover. then from croosover to the alpine woofer and tweeter.
I have a 04 silverado do i need to install my
With component speakers it is imperative that both the speakers be hooked up to the supplied crossover. Wiring them in series or parallel will not yeild satisfactory results since the woofer requires lower freequency then the tweeter, which plays the high notes.
Now some cheaper speakers do not use crossovers and sound rather poor. What make and model of speaker are installing? Does you truck already have component speakers in it?
Cheers,
How do i wire the system withouth an amp on an
Hello nestoramenen,
Connect the wires coming from your receiver to the woofer terminals along with the included inline crossovers. Connect the other end of the crossovers to the tweeters.
I need a Manual for a Alpine Vie-x077 in English and also anyone know why it keeps saying the disc needs to be ejected but it won't
- Mechanical Issue: There might be a mechanical problem with the disc drive or the eject mechanism. It's possible that a part is jammed or not functioning correctly.
- Dirty or Damaged Disc: If the disc is dirty, scratched, or damaged, the player may have difficulty reading it and thus not ejecting it properly.
- System Error: There could be an internal error within the player's software or firmware causing it to not recognize the disc properly or to malfunction when attempting to eject it.
- Power Issue: Sometimes, power-related issues can affect the functionality of electronic devices. Ensure that the player is receiving adequate power and there are no loose connections.
Here are some troubleshooting steps you can try:
- Turn off the player and then turn it back on to see if it resolves the issue.
- Try ejecting the disc using the manual eject button (if available). This button is usually a small pinhole near the disc slot. You can insert a paperclip or a similarly sized object into the hole to manually eject the disc.
- If possible, try using a different disc to see if the problem persists. If other discs work fine, then the issue may be with the original disc.
- Check for any visible obstructions around the disc slot and remove them if present.
- If none of the above steps work, you may need to contact Alpine customer support for further assistance or consider taking the player to a qualified technician for repair.
My Alpine CDE-W235BT bluetooth has stopped working
Se o Bluetooth do seu Alpine CDE-W235BT parou de funcionar ap?s uma falha durante a atualiza??o, pode haver algumas etapas que voc? pode tentar para resolver o problema:
1. **Reinicie o Aparelho:**
- Desligue o r?dio por alguns minutos e ligue-o novamente. Isso pode reiniciar o sistema e resolver problemas temporariamente.
2. **Restaurar as configura??es de f?brica:**
- Consulte o manual do usu?rio para descobrir como realizar uma restaura??o das configura??es de f?brica em seu Alpine CDE-W235BT. Isso pode resolver problemas causados por configura??es incorretas.
3. **Verifique a vers?o do firmware:**
- Se poss?vel, verifique a vers?o do firmware do seu Alpine CDE-W235BT. Se houver uma vers?o mais recente dispon?vel, considere atualizar novamente o firmware, seguindo rigorosamente as instru??es do fabricante.
4. **Remova Dispositivos Pareados:**
- No menu Bluetooth do r?dio, remova todos os dispositivos pareados anteriormente e, em seguida, tente parar novamente. ?s vezes, problemas de conectividade podem ser resolvidos removendo e pareando novamente os dispositivos.
5. **Atualiza??es de Software:**
- Verifique se h? atualiza??es de software dispon?veis para o seu Alpine CDE-W235BT no site do fabricante. Caso existam, siga atentamente as instru??es para realizar a atualiza??o.
6. **Contate o Suporte T?cnico:**
- Se as solu??es acima n?o resolverem o problema, entre em contato com o suporte t?cnico da Alpine. Eles podem fornecer assist?ncia espec?fica para o seu modelo e orienta??es adicionais para resolver o problema.
Lembre-se de que mexer no firmware e nas configura??es do dispositivo envolve riscos, e ? sempre recomend?vel seguir as instru??es fornecidas pelo fabricante para evitar danos permanentes ao aparelho. Se voc? n?o se sente confort?vel fazendo isso por conta pr?pria, procurar ajuda profissional pode ser uma op??o.
Alpine tdm 7543. Is this a model that can switch from green to red lighting?
After researching, it appears that there is no direct evidence suggesting that the Alpine TDM 7543 stereo unit has the ability to switch from green to red lighting. This is an older unit and specific information can be challenging to find. Your best option to get a definitive answer may be to directly contact Alpine's customer service or refer to the original instruction manual.
