20 Most Recent
LG LP1200DXR Portable Air Conditioner Questions & Answers
CH 02 error code
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5 kOhm at 25C. If not replace sensor.
How do you drain the water?
there should be an upper drain and lower drain in the back bottom of the unit unplug the drain plug and voila!!
I have the LG LP1200DXR and it is leaking near the
All air conditioners collect condensate. It has to drain somewhere. Try connecting tubing to the drain hole or port. In order for air conditioners to remove heat from a space, they also remove humidity, which is water vapor in the air. Like placing a cold beverage in a warm room, it will form condensate (water) around it. The water that you were trying to drain out already leaked out. This is a normal thing for condensation to form when cooling. The condensate needs to be emptied regularly or piped with flexible tubing to a window or plumbing.This is the same as water dripping from your car while the A/C is on.
It shows the FL error
tip the zircon back a little bit and water will pour our. I did this because i had the same problem. This solves it
