20 Most Recent Goldstar DH2510A Dehumidifier Questions & Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Goldstar DH2510A... | Answered on Sep 17, 2011
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. (# 2, you have already taken care of)
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit, turn the knob to Maximum
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement application . Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Goldstar DH2510A... | Answered on Jul 13, 2011
Remove the tank and locate the switch and 'teeter' (that the tank sits on). Make sure the tank is able to move when filled. You will have to adjust the position of the switch to allow the filled (teetered) tank to shut the device off.
Is it possible for you to drain the water into a nearby floor drain using a hose?
Thanks for your question @ FixYa.com
Goldstar DH2510A... | Answered on Jun 26, 2011
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Goldstar DH2510A... | Answered on Mar 30, 2011
The unit is low on charge...
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Goldstar DH2510A... | Answered on Sep 29, 2010
Here is a tip that will help you...
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Goldstar DH2510A... | Answered on Jun 08, 2010
Most communities have either private or charitable organizations that take old appliances and computers. I took an old window air conditioner and they took it with no prep.
Goldstar DH2510A... | Answered on May 18, 2010
The largest culprits for freeze up are dirty filter, dirty coil behind filter....and on certain occasions, low on freon.
Goldstar DH2510A... | Answered on May 13, 2010
The DH304Y5 dehumidifier is not subject to any recalls at this time.
I hope this helps.
Goldstar... | Answered on Sep 10, 2017
I can't hear YOUR dehumidifier and can't tell if it's out of the ordinary, but dehumidifiers have all the same internal parts as a refrigerator with the addition of a fan to blow air through the coils to keep them from freezing up. They do tend to be a bit noisy.
Goldstar... | Answered on Feb 22, 2015
any appliance that trips the fuse or breaker should not be tried to use by homeowner this is a fire hazzard as an electric short is a dangerous situation to have in any home , replace unit ! ck with mfg for recalls first and warrentys as well then contact your power company sometimes they give rebates for appliance upgrades but they require old ones back in order to pay u money on them
Goldstar... | Answered on Oct 23, 2014
unplug and wait a few minutes then reconnect to power to clear buttons not working , then ck filter to see that its not clogged use a flashlight to view inside to see if a heavy coating of dust exists iniside case , if so you might be able to save it if you unplug and remove case to access inside and clean out with vacuume hose coils are most important to get clean
ck your humidistat settings sometimes these get changed No one knows why ? 70%rh is considered normal
Goldstar... | Answered on Oct 22, 2014
Goldstar DH2510A Dehumidifier Logo
Popular Tags
13 questions posted
Top Goldstar Dehumidifiers Experts
Gil Shultz
Paul
Paul
Michael Youngman
Michael Youngman
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Goldstar Dehumidifiers
Most Popular Question
unit runs but not moisture from
  • Dehumidifiers
