20 Most Recent Canon FS100 Flash Media Camcorder Questions & Answers
I guess the lens cover mechanism is stuck.
Canon FS100... | Answered on Jan 06, 2015
The default is to start a new clip every time you press the stop button, but in settings you might be able to tell the camera to continue with the same clip provided you press record again with a set time. Not sure why you want to do this though - it's much easier to edit using small clips than very large ones.
Canon FS100... | Answered on Aug 29, 2014
It sounds as though it may have become overheated. If it continues to show this problem and the camera is not too warm when used then it may have been damaged by the heat. Temps in cars can get very hot. It could also be a physical damage issue if the camera was not in a case and slide around unprotected.
Canon FS100... | Answered on Jun 02, 2014
Plug in a 3.5mm stereo "pin" plug, into the external microphone input. This will open the internal microphone circuitry and allow for silent recording.
Canon FS100... | Answered on May 25, 2014
u shouldnt hav kept it in car...the interior tmp of the car raises due to green house effect...excessive heat exposure might hav damaged ur cam...remove the battery try to keep it untouched for a week...if the porblem persists then replace the lcd....
Canon FS100... | Answered on May 23, 2014
I experienced the same thing. The compact power adapter is simply the power cord used also to recharge the camcorder. Plug it into the wall at the same time as you have the USB plugged into the computer and it should be able to download.
Canon FS100... | Answered on Dec 11, 2013
you have to leave in your sd card
Canon FS100... | Answered on Nov 05, 2013
The Date/Time command is in the DATE/TIME SETUP menu. See page 81 of this manual:
Canon FS100... | Answered on Oct 20, 2013
Good Evening Pat
You will be fine, its just a standard warning that comes up when you dont use the same brand memory card.
If the camera is able to record and upload the video to your computer or TV then you should have no problems at all.
I hope you enjoy the wedding.
Thanks
Canon FS100... | Answered on Sep 19, 2012
Canon FS100 Flash Media Camcorder Logo
118 questions posted
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
FS Canon
  • FS Canon
Most Popular Question
canon fs100 time lapse recording
  • Video Cameras
