20 Most Recent Goldstar DH4010B Dehumidifier Questions & Answers
Hi, Yes. I would say that your compressor is dead...
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Goldstar DH4010B... | Answered on Sep 27, 2015
TURN POWER OFF AND REMOVE THE PLUG FROM SOCKET
rewier this part and replace capacitor
Goldstar DH4010B... | Answered on Aug 18, 2012
The water tank is available online at http://www.appliancefactoryparts.com/search/partinfo.php?partsID=276540&modelsID=124794&typeName=dehumidifier
It's the same one that's used in the similar LG model. Which makes sense, LG makes Goldstar.
Hope this helps you and thanks for choosing FixYa.
Goldstar DH4010B... | Answered on Aug 07, 2011
Try to change the filters..and after that if it has a reset button reset it ..or make a power reset...by removing the power cord..placing it back ..and when you turn it on ..keep the power button pressed until it starts..(no less than 10 seconds or so ...The beeping sound may indicate the filter being issued or dirty ...or something like that ...There can be no other fault if it receives the power and beeps..on start
Goldstar DH4010B... | Answered on Jul 16, 2011
Do you have power to the fan motor? If you do have power to it the motor needs to be replaced good luck trying to find one and if you do find one you will pay a lot for it. Buy a new dehumidifier they are cheap and disposable.
Goldstar DH4010B... | Answered on Jun 30, 2011
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Goldstar DH4010B... | Answered on Jan 03, 2011
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Goldstar DH4010B... | Answered on May 18, 2010
No there is no way to lubricate the fans internally...they are made to run for a bit and then be thrown out...
I have found that by using a thin oil like WD-40 and then positioning the motor so that it runs back the shaft into the motor you can get it to work into the motor. I usually use WD-40 and then follow with a light motor or sewing machine oil. This seems to give a longer solution...
heatman101
Asker's Testimonial " Just the advice that I expected, and what I had already performed Dehumidifier is running but no water is in bucket
Goldstar DH4010B... | Answered on May 07, 2010
If you pull out the water collection tank the unit tag should be inside behind where the tank goes.
Goldstar DH4010B... | Answered on Aug 28, 2009
water is not draining properly. make sure unit is balanced upright and there are no clogs preventing the water from draining
Goldstar DH4010B... | Answered on Aug 26, 2009
Is the compressor on as well? or just the fan, if the compressor is on and fan is on and it is blowing warm air it could be a charge (refrigerant problem)
Goldstar DH4010B... | Answered on Jul 27, 2009
You may have a blockage in the metal or plastic collection pan under the coil that sweats to take water out of the air. Possibly some pet hair, lint etc. Have you cleaned it lately? Could the pan be rusted through somewhere? Is it level? Could you the collection bucket be cracked at or near the hose connection?
Goldstar DH4010B... | Answered on Jun 27, 2009
The DH304Y5 dehumidifier is not subject to any recalls at this time.
I hope this helps.
Goldstar... | Answered on Sep 10, 2017
Goldstar DH4010B Dehumidifier Logo
23 questions posted
Top Goldstar Dehumidifiers Experts
Gil Shultz
Paul
Paul
Michael Youngman
Michael Youngman
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Goldstar Dehumidifiers
Most Popular Question
lg dh504e goldstar dehumidifier
  • Dehumidifiers
