20 Most Recent KitchenAid KBFS25EVMS Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
It won't stop making ice. HELP!!!
The ice unit is available online. U can disassemble the unit and see if u can spot the problem also. It is not complicated If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
4/14/2018 5:38:10 AM • KitchenAid... • Answered on Apr 14, 2018
NO ICE OR WATER
Whenever the water lingers inside the freezer, it freezes. If the valve has a slow leak, or the final outlet tube is scratched, ice can build up and eventually block entry. A hair drier on the area where water enters the freezer might clear up the problem. I'm not sure that's a prescribed method to melt the ice though. Defrosting the freezer could thaw it out, but where do you put the frozen items?
12/17/2017 5:12:04 AM • KitchenAid... • Answered on Dec 17, 2017
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
11/1/2013 1:45:30 AM • KitchenAid... • Answered on Nov 01, 2013
Starrett 64 indicator compressor
Buy new one from Ebay
6/8/2013 3:49:34 AM • KitchenAid... • Answered on Jun 08, 2013
0answers
Kfis29pbms
Be the first to answer 4/1/2013 5:34:47 PM • KitchenAid... • Posted on Apr 01, 2013Be the first to answer
My kitchen aid refrigerator is not cooling
Could you tell me if the compressor is running?
11/13/2012 5:25:21 AM • KitchenAid... • Answered on Nov 13, 2012
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
7/26/2012 10:20:09 PM • KitchenAid... • Answered on Jul 26, 2012
Ice forming in the bottom
Check the seal on the door and make sure it is "sound". Pay particular attention to the bottom or underside of the freezer door / drawer. Make sure nothing is preventing a seal between the fridge case and door. Misfigured, distorted or otherwise damaged seals can cause frost build up as you describe. Clear any objects / replace damaged seals found.
9/6/2011 8:45:52 PM • KitchenAid... • Answered on Sep 06, 2011
When the right hand door is opened greater than 48
HI,CHEK THE DOOR BY THE HINGE PROBABLY THE DOOR STOPER IS BAD..
7/5/2011 3:41:27 AM • KitchenAid... • Answered on Jul 05, 2011
My KFCS22EV periodically makes a
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
4/21/2011 2:26:11 AM • KitchenAid... • Answered on Apr 21, 2011
My fridge never goes off
is everything staying cold and machine is running normal other than running all the time?if so remove the bottom kick plate and clean the condenser coil off,if this is loaded with lint it will cause the machine to run longer because the lint is holding the heat in,this is how the machine cools down along with the condenser fan.you can pull out the machine and remove the bottom panel in the rear also and clean that out,make sure the fan is running then unplug it and clean it,i use a shop vac and a brush to do this,vac as much as you can then stick the brush through the coil holes and pull out as much lint as you can,then i stick the vac on blow and blow through the coil with short blasts so the dust and lint doesn't fly everywhere.you should do this once every 6 to 12 months.this will make a big differance on how the machine runs.
3/26/2011 2:44:45 PM • KitchenAid... • Answered on Mar 26, 2011
I have a french door side-by-side refrigerator.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
9/20/2010 12:47:52 PM • KitchenAid... • Answered on Sep 20, 2010
Why is there number 3 at the end of my refrig
The number means there have been 3 versions of this model. The model is the same on the sales floor but has had some type of minor change, the numbers change so the field can determine what parts go with the specific model. For example a '2' model may have had a certain type of shelf and that shelf was changed for '3' models. The change was minor but somehow the model number has to change to make sure the right parts go with the model. It could also be a component you do not see, such as a motor or wiring harness, anytime something is changed and only has minor effects the last number changes. I hope that helps.
The example of a shelf is only an example and does not mean that applies to your particular model.
4/18/2010 7:57:32 PM • KitchenAid... • Answered on Apr 18, 2010
Ice maker not working
Use this link to troubleshoot your Icemaker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Unless you have a defrosting problem that is causing the Freezer section to be just above the temp where the icemaker would function, the manual / link above will isolate the problem.
3/6/2010 9:40:31 PM • KitchenAid... • Answered on Mar 06, 2010
KitchenAid KBFS25EVMS Stainless Steel Bottom Freezer French Door Refrigerator Logo
38 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
kitchen aid refrigerator not cooling
  • Refrigerators
